Old 30-12-2008, 05:41 PM   #1 (permalink)
Default Will I have a Gaming PC??
Hi
I am gonna upgrade my system to the following specifications:
2GB DDR2 Ram
2.4 Intel Core 2 duo
945 chipset Gigabyte motherboard
I'm also planning to buy an ASUS 512 MB graphic card.
Will this be enough to play crysis, bioshock and fallout like games on low resolutions and high details?
RaghavKanwal is offline
Old 30-12-2008, 06:20 PM   #2 (permalink)
Default Re: Will I have a Gaming PC??
depends on what resolution you'll be playing in.
if you're gonna get a 512Mb GpU i suggest an 8800GT or a HD4850 (i use one), if you can stretch your budget a bit you might consider a HD4870, or if you are in a tight budget constraint, go for a 9600GT. (check up on HD4830 once though)
I would recommend AGAINST the 945GZ, go for a MSI P45 instead, they're good overclockers and have fine expansion possibilities,
2GB RAM is sufficient to run most games at 1280x1024, and Core2s are generally good overclockers.
A GPU is generally MORE important than your other components, but having poor CPU and RAM will bottleneck it and having a poor Mobo will in turn bottleneck your entire system.
You will also need a good PSU to run all that stuff, say a CM 600W or a Corsair 450VX. If you are a heavy downloader, i will also suggest a large HD, trust me you will NEED it before long. a 500GB cost my friend about 3 grand.
ToxinX is offline
Old 30-12-2008, 11:51 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
avoid 945 chipsets.they'll be a huge bottleneck in overall sys perf.
if ur budget doesnt permit a P45 based mobo then atleast get a P31/P35 chipset based mobo.
hellgate is offline
Old 31-12-2008, 11:00 AM   #4 (permalink)
Hey I have 500 gigs. got it for the price of a 250 gig HD!!!!<thnx seagate >
Also, my budget does not allow me to add sumthing else..
So,i just need to know whether i can play the games at a resolution of 600 X 800<with fullscreen, of course> and high details.....
Thanks in advance.
Old 31-12-2008, 12:43 PM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Will I have a Gaming PC?? seems like an Astrological Question
- MrinTech: http://mrintech.com/
mrintech is offline
Old 31-12-2008, 01:43 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
@RaghavKanwal do mention ur budget to get proper replies.
hellgate is offline
Old 31-12-2008, 02:43 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yup, and wich world r u in?
U want gaming, and u r seeing 945, u need specs man, high power that too
http://pleaseguide.me/
comp@ddict is online now
Old 31-12-2008, 06:14 PM   #8 (permalink)
The Sorcerer's Avatar
Mind telling us your budget or else some posts might exceed your pockets.
Hardware BBQ
The Sorcerer is offline
Old 01-01-2009, 07:32 PM   #9 (permalink)
yeah and before you realized it..ur pocket will be emptied
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse debasis_7012005 Hardware Q&A 24 10-09-2007 02:37 PM
Gaming rig for Rs 80,000 ratzee199 Hardware Q&A 12 03-04-2007 06:20 PM
what's the difference btwn Online gaming & Internet gaming singh Gamerz 2 12-08-2006 12:03 PM
Gaming PC for 60k devilhead_satish Gamerz 18 22-05-2005 08:10 PM
Can small gaming companies suceed in todays gaming market Charley Technology News 16 03-03-2005 10:56 PM
