Originally Posted by MetalheadGautham
Rs. 7700 ? Where ? Because then you may as well get it.
Are you buying in SP Road or National Market ? If so, please check that warranty is available.
But lolz at the specs. 4:3 wide, and 1440x900 resolution ?
Then its 16:10, not 4:3.
Thats actually a GOOD thing, but typographical errors like these are quite amusing.
I think warranty will be available.
Yes its in SP Road.
Yes, the same mistake is also there in the handbills also.
It says 8000:1 contrast ratio. Is it better compared to Dell's 1000:1 CR or it does'nt matter? Please answer.
Regards,
Subrata Bera.
Actually the 4:3 aspect ratio is not a misprint. Its a feature of that monitor to auto adjust itself according to the image or video size.
