Old 29-12-2008, 11:39 PM   #1 (permalink)
Default a decent gamin rig for 20k-25k
well m at da verge of upgrading my CPu..i need a new rig 2 satisfy my gaming needs
am going 2 upgrade my processor,mobo...n graphic card..and ram
so cld u suggest my a good combo of all these thing which wld fit in2 my 20k-25k budget.
shld i prefer an intel or a AMD processor??
justin9180 is offline
Old 30-12-2008, 06:30 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: a decent gamin rig for 20k-25k
Proc - Intel e7300/e7200 for Rs. 5100
Mobo MSI P45 Neo F Rs. 6000
Gfx Card Palit HD 4850 Rs. 9500
Ram 2x I GB 800Mhz For Rs. 1200
Corsair VX 450W For Rs. 3800
Total Rs. 25600
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 30-12-2008, 12:44 PM   #3 (permalink)
n wat r my chances...if i opt 4 a AMD rig??n a ASUS mobo??heard they have some really awsome..mobo'z n if i include a XFX graphic card!! den i can have a monster rig 4 da same budget..is dat true??
n does AMD still have those "overheating" issues?i thgt those guys fixed'em up!!
Old 30-12-2008, 01:36 PM   #4 (permalink)
Since you are getting a separate gfx card, it is better to stick to Intel... AMD doesnt have overheating issues, but it is lagging behind Intel in performance... Its advantage is that its motherboards have much better IGP than Intel mobos but that is not important here...
Arun
sakumar79 is online now
Old 30-12-2008, 01:44 PM   #5 (permalink)
am not a big comp geek but i heard my frnds dat if i invest in a quad core..da games that are out...dont fully utulise..the quad core capabilities...so...is it wise 2 invest in a quad core if my priority is a serious gaming rig!!...
i need ur help ...big time forum members..cause am gona finalise da hole config..by next week... so i need ur opinion ..asap!!! cld u!!
Old 30-12-2008, 09:46 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
Most of the games are dual core optimised but quad is the future.
Get q8200 For Rs. 10000
topgear is offline
Old 02-01-2009, 11:06 AM   #7 (permalink)
Mike84's Avatar
Athlon 64X2 5000+ -- 2900
Asus M2A MX mobo -- 2300
OCZ Value 2GB ram -- 950
CoolerMaster 460W Ext Pw -- 2400
Palit Dual Sonic HD 4870 512MB --
15850
Total : 24400.
If you can increase ur budget a bit get the Palit aa 780g MOBO... (3800) A lot better.
Also If you can increase a bit more... get the Athlon X4 5600+ for 3900.
At 2.9GHz speed ur processor will never be a bottleneck. (Though loading screens will be a bit longer compared to intel, the gameplay hit is quite negligible)
Total budget 26900
Athlon 2000+@2.1,MSI KM2M combo,1GB 266MHz DDR,5200FX 128MB,15" LG CRT,12X HP DVDRW
MSI GX720 - P7350 (@2.34), 4GB DDR2 800MHz, 320GB HDD, 512MB DDR3 9600M GT,17" with 1680X1050 res. ;)
Mike84 is offline
Suggestions 4 New Gamin Cpu[30,000-35,000]rs. n rate my older PC detonator2359 Hardware Q&A 67 23-12-2008 08:54 PM
New Gamin PC [Very tight on budget] atish Hardware Q&A 30 10-06-2008 03:03 PM
new gamin PC config buddystar PC Components / Configurations 10 21-04-2008 12:50 PM
gamin mouse + gamepad.. ssk_the_gr8 Gamerz 5 01-04-2008 01:14 PM
wanna buy a gamin pc anshumanarora QnA (read only) 17 26-06-2005 02:00 AM
- by c4u
