Old 29-12-2008, 02:29 PM   #1 (permalink)
Default TFT Monitor showing "Auto Adjustment In Progress"
Hi,
Just 2 months back i have bought a new compaq desktop with 19" TFT. The model no is HP W1907. Now after a week of use the monitor started displaying "auto adjustment in progress" message. The whole screen blacks out and the message stays for few seconds and then vanishes. It again comes back after few seconds. This keeps happening everytime. I contacted HP care. The service guy came and told issue with TFT. He told a replacement will be sent. They sent a refurbished one which had quite a few scratches. I didnt accept the monitor. they told they will send one more TFT.
can you guys please help me with this issue. i checked the TFT thoroughly but there seems to be no way for turning off the "auto adjustemnt feature". Why is this happening? Is it a TFT issue? I think the issue might lie somewhere else as sometimes the system works fine.
Please help
Regards
Sunny
sunnythedreamer is offline
Old 30-12-2008, 06:59 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: TFT Monitor showing "Auto Adjustment In Progress"
Auto adjustment occurs when resolution or refresh rate of the display changes. Looks to be a prob with the monitor.
Check your display setings in os. Set them properly according to your manual.
Update your display adapters driver.
Also chek your gfx card or mobos display port & try using a different cable.
try pluging the monitor to a different computer or plug in a different monitor wih your
mobo or g cards display port.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
how to use" Auto Power On and Shut Down" software 4 bsnl home 500 Combo plan hskpunjabi Software Q&A 3 25-06-2008 09:15 PM
NEW VIRUS GIVING MESSAGE:"Can not find script file"WIN32.DLL.dll.vbs" ". mdp Software Q&A 5 02-10-2007 02:11 PM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
LG 15" Monitor gets "out of resolution". emailaatif786 Hardware Q&A 1 12-11-2006 01:41 PM
- by c4u
