Old 29-12-2008, 02:02 PM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default IDE to SATA converter cable
I am looking for an IDE to SATA converter cable for helping me reconfigure my messed up hard drive and couple of DVD writers all of which are IDE, and may be getting company soon thanks to a second hand product.
I have an Intel D915GLVG motherboard with only 1 IDE port (2 devices) but around 2-4 SATA ports.
So I need an IDE to SATA cable.
How much do they cost and how reliable are they ?
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 30-12-2008, 06:53 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: IDE to SATA converter cable
There is no convertor cable
They are called IDE to Sata convertor card or adaptor.
A little red card like thingy.
Last year on june I also checked the price in one shop. They quoted Rs. 70 only.
But when on deccember I checked ( It was not available on the Shop No. 1 ) the price on e shopkeeper told Me It's Rs. 450 & another told me it's 285.
So prepare to make a good bargain before buying one
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 30-12-2008, 10:44 AM   #3 (permalink)
The Smaller Bang
thanks 4 da advice.
Old 30-12-2008, 09:49 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
My pleasure buddy.
topgear is offline
Old 31-12-2008, 11:17 AM   #5 (permalink)
The Smaller Bang
Wait a sec, are you talking about PCI cards or cards which fit in existing SATA port ?
I want a conformation on that one.
And yeah, its suppsed to convert SATA port to IDE port or, IDE device to SATA device and NOT IDE port to SATA port
Old 31-12-2008, 09:57 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
The card I'm talking about is not a PCI card.
This card have one IDE port on one side & a sata port on other side.
You have to attach it to your IDE device. Your IDE device should work as sata.
I would say should not will coz I've seen some find It's not detecting their Hdds & others find it working.
This card need to be powered by a floppy power caable. ( Though Molex to floppy power cable is provided )
topgear is offline
Old 07-01-2009, 01:42 PM   #7 (permalink)
The Smaller Bang
The pic the Rs. 75 card ?
Old 07-01-2009, 09:14 PM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
It was Rs.70 for the first time ( maybe shopkeeper was mistaking
But after some months It was quoted Rs. 450 & Rs. 285 by two different shopkeepers.
topgear is offline
Old 08-01-2009, 09:38 PM   #9 (permalink)
Tech Addict
I'm also in search of one. Who quoted Rs285 in Kolkata?
Arihant quoted Rs. 450 to me.
Pls help.
arupch is offline
Old 09-01-2009, 03:16 AM   #10 (permalink)
Point Blanc
they may sound good, but are rubbish. how to power them may get you confused.
as you will need 2 power ports, one to power this adaptor and then to the device also both separately.
Better get PCI cards with IDE or SATA ports whichever you need. THey will have 2 IDE port or 4 SATA port in them and will use one of your PCI slots
What I am suggesting is PCI to SATA or IDE
requirement of 2 power ports make the SAT to IDE or vice versa a messy substitute for convertors, that is what I would say.
acewin is offline
Old 09-01-2009, 08:02 AM   #11 (permalink)
RMN
i have that thing.....its easy to connect but it took me 3 days to get it working my pc just would not detect it but after it started to work i had absolutely no probs...i was using it to convert my SATA to IDE...
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 09-01-2009, 10:40 AM   #12 (permalink)
Tech Addict
Thanks for the info guys.
arupch is offline
Old 22-01-2009, 04:15 PM   #13 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
thanx 4 info ......much needed 1 ....... as many times my ide drives [hdd & dvd ritter] dont get recognized @ all ......
will also check the price .......
... W H O T ...
ax3 is offline
Old 07-03-2009, 02:21 PM   #14 (permalink)
recenty 2 of my sata ports broke in my motherboard..(out of 4)
i have 3 sata devices (2hdd's and 1 SATA DVD writer)..
so can i use the above mentioned device to make my dvd writer work...by connnecting it to the device and to IDE port in motherboard ??
huntersvk is offline
Old 08-03-2009, 05:30 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
That should work but there is no guarantee that it will work.
If you want to find out you have to try one.
topgear is offline
Old 08-03-2009, 09:28 AM   #16 (permalink)
Stuge's Avatar
sadl;y ,these cards never worked for me
Stuge is offline
Old 09-03-2009, 06:14 PM   #17 (permalink)
Default Zippy's SATA <=> IDE Convertor
It worked both ways..SATA to IDE and IDE to SATA..
The card has 2 sata ports..
1 doesn't work..
It shows as Primary Master under BIOS when connected
Old 10-03-2009, 06:15 AM   #18 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ How much did you pay for that card ?
topgear is offline
Old 10-03-2009, 08:49 AM   #19 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 11-03-2009, 08:44 AM   #20 (permalink)
-_- Macs Suck -_-'s Avatar
this is easy stuff - thought you geeks would have known *sighs*
Posted again:
Posted again:
Last edited by -_- Macs Suck -_-; 11-03-2009 at 08:54 AM. Reason: Automerged Doublepost
-_- Macs Suck -_- is offline
Old 11-03-2009, 11:57 AM   #21 (permalink)
Rs. 300 for it.. in bangalore..
I returned the card and bought a "PCI SATA Controller Card"
It has 3 sata ports (all working) and 1 IDE port in it..
Price 400rs..
Sata To Ide Converter j4jubin Hardware Q&A 1 04-09-2008 06:09 PM
Install windows on a sata HDD connected through IDE to SATA converter bhunnu16 Hardware Q&A 3 10-01-2008 04:22 PM
SATA cable da_tcpip Hardware Q&A 6 03-02-2007 03:51 PM
SATA/SATA-II converter ..:: Free Radical ::.. Hardware Q&A 10 26-01-2007 08:21 PM
wat is e-sata cable nightkumar Hardware Q&A 8 07-12-2006 10:18 AM
- by c4u
