Old 28-12-2008, 07:32 PM   #1 (permalink)
wiZard member
vvikas28's Avatar
Default system upgrade
guys i am unable to play games like quake4, vegas2,arma etc. at high details because after about 20 min system hangs and display message that disply driver stoped working need to restart. but quake4 works fine at mid settings some suggested me to upgrade proc, ram,mobo.
my current config is-
pro- amd3000+
mobo- msi rs 480m2
gcard- palit 4850
ram- 1.25gb
psu- antec ea650w
now i want to upgrade my proc mobo ram. i have short listed following configuration from lynxindia online shopping store PLEASE SELECT FROM FOLLOWING TO MAKE BEST UNDER 23K BUDGET-
proc.- intel E8500 - http://www.lynx-india.com/index.php?productID=3199
E8400- http://www.lynx-india.com/index.php?productID=1133
MOBO- ASUS P5Q- http://www.lynx-india.com/index.php?productID=2752
BIOSTAR TPOWER I45- http://www.lynx-india.com/index.php?productID=3236
MSI NEO3-FR- http://www.lynx-india.com/index.php?productID=2944
MSI P45NEO-F - http://www.lynx-india.com/index.php?productID=2667
RAM- Corsair TWIN 2X2048-6400C4-2GB X2- http://www.lynx-india.com/index.php?productID=686
corsairTWIN 2X 4096-6400C4DHX 4GB - http://www.lynx-india.com/index.php?productID=1580
Corsair TWIN2X4096-6400C5 4GB - http://www.lynx-india.com/index.php?productID=1583
G-skill 4 GB - F2-6400CL5D-4GBPQ- http://www.lynx-india.com/index.php?productID=1010
OCZ Edition Dual Channel DDR2 800MHz 4G- http://www.lynx-india.com/index.php?productID=2688
I ALREADY HAVE-
PALIT 4850 GRA CARD
ANTEC EA650WATTS PS
and want to use this for gaming on xp , ocasionally use vista64 bit and i have budget of RS 23000 MAX SO PLEASE CHOSE BEST CONFIGURATION FROM ABOVE MENTION.
I ALSO HAVE SOME QUESTION-
ram- is it better to go for 4 stics of 1gb or 2 stics of 2GB
which latency is better 5-5-5-18 or 5-5-5-12 and how much
MOBO- with cosidring prices which one has better overclocking capacity AND DOES IT WORTH PRICE DIFFERENCE
what is diff between MSI neo3fr and MSI neo-f
PROC- if budget dont allow going for E8500 should i go for E8400 or E8200 and how much difference it make in gaming
are prices mention in LYNXINDIA including VAT?
THANKS IN ADVANCE.
vvikas28 is offline
Old 29-12-2008, 05:58 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: system upgrade
Proc - e8400 Rs. 8800
Mobo - Asus P5Q Rs. 8700
Ram - corsairTWIN 2X 4096-6400C4DHX 4GB Rs. 5500
Total Rs. 23000
Go for 2 Stick of 2GB
Asus P5Q
e 8400
Try here also : http://www.theitwares.com
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 29-12-2008, 10:41 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ come on. He wants to play games. and he want a config with video card under 23k.
I would say:
1) E8400: 8.5k or E7200 : 6k
2) MSI P45 Neo-F: 5k
3) Transcend/Kingston two 2GB sticks : 700 bucks each
4) Palit HD4850: 9.5k
5) Corsair VX450 PSU: 3k
desiibond is offline
Old 29-12-2008, 12:47 PM   #4 (permalink)
wiZard member
vvikas28's Avatar
I HAVE 23K FOR PRO+MOBO+RAM
i alredy have palit HD4850 and antec EA650 watts psu.
vvikas28 is offline
Old 29-12-2008, 01:13 PM   #5 (permalink)
G.A.M.E.R
Shloeb's Avatar
Go for Quad core processor. It wil be beneficial in the long term. Most of the new games are being optimised for Quad cores. There's no use of a fast dual core as most of the work is done by the gfx card. If u ask me i'll suggest this:
Processor-> Q8200- 10k
Mobo-> MSI P45 NEO2 FR-8.3k
RAM->Get Corsair 2x2GB in dual channel.-2.2k
Core2Duo E7200 @ 3.16 Ghz| ABIT IP35-E | 2GB Transcend 800Mhz | GeCube ATI HD 4850 | 250 GB Western Digital | Corsair VX450W
Dell Studio 1558
Shloeb is offline
Old 29-12-2008, 01:42 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
in that case, just wait another month!!!!
Old 29-12-2008, 05:35 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
I would say:
Haven't you read his 1st post Read before you post
Though it's long I've read it thoroughly
C4 rams performs better in memory intensive tasks line gaming than value c5 rams.
& where in the the earth you're getting 2GB sticks for only Rs. 700.
Can you give me some address or links.
I've bought transcend 2GB 800Mhz stick for Rs. 1075 this month.
He aleady own HD4850 and Antec 650w psu.
topgear is offline
Old 29-12-2008, 10:43 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ow. you are correct. My mistake. And correction for the RAM price too. sorry, posted in a hurry.
Anyways. I think it's better to wait for a month or two if you want to spend 25k on proccy mobo and RAM.
Old 30-12-2008, 07:39 AM   #9 (permalink)
Rig It Up
Hi, i too have a budget of 25-30k for a gaming rig without monitor...plz help me out..i am thinking of the following coz they get zero1 awards...
mobo MSI P7NGM Digital
ram 2x 2GB DDR2 800 Mhz corsair
pro Core 2 duo E8400
grafix EVGA 9600GT
plz tell me is this good config or can get better..and plz tell me the price of each...
Crossfire is offline
Old 18-02-2009, 07:39 PM   #10 (permalink)
wiZard member
vvikas28's Avatar
Thumbs up Re: system upgrade
thanks to topgear, desibond and Shloeb for your suggestion. i have bought following -
core2duo e8400
g.skill 2+2gb 800mhz 4-4-4-12
sunbeam corecontact freezer 120mm
gigabyte p45 ds3l
other addition-
samsung dvd writer 22x
sunbeam ccfl tube
and now my all problems are solved.playing games at ultra high quality smoothly
vvikas28 is offline
Old 18-02-2009, 08:40 PM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
grafix EVGA 9600GT
For mobo Get MSI P45 Neo F Rs. 6k
Palit HD 4850 512MB DDR3 GFX card Rs. 8K
core2duo e8400
gigabyte p45 ds3l
other addition-
sunbeam ccfl tube
Congrats. Wish you Happy Gaming
topgear is offline
system slowdown after sp3 upgrade sumigizlov Software Q&A 1 19-06-2008 09:09 PM
Need help to upgrade system raj_82_18 Hardware Q&A 1 26-10-2007 08:49 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
system upgrade readermaniax QnA (read only) 14 01-08-2005 11:19 PM
system upgrade!!! karthik316_2003 QnA (read only) 7 25-05-2005 02:01 AM
- by c4u
