Old 28-12-2008, 01:27 PM   #1 (permalink)
Exclamation Pc not turning on when connecting HDD
I have another problem with my pc now , i got my new hdd after my previous one got damaged ..
my pc dosent start when hdd is connected . when i press the start button quickly the lights glow and then goes off .
but when i remove the sata 2 hdd cables i am able to get the boot message etc ..
now i am scared if my new hdd will also get damaged ..
My config is
2*1 gb 800 mhz ddr2 transcend ram
c2d 6750
abit ip 35 mobo
wd 320 gb HDD
xfx 8600 gt
frontech 500 watts power supply
please help me , does this have some thing to do with the power supply ?
eureca_eureca is offline
Old 28-12-2008, 02:39 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Pc not turning on when connecting HDD
^It might be your PSU issue...the same thing happened to me with my graphics card and 500W PSU...i changed to 700 and everything was fine.
My site: collegeclassroom.org
amitash is offline
Old 28-12-2008, 04:46 PM   #3 (permalink)
is 500 w not sufficient for mine ?
Almost one year it worked fine .
Old 30-12-2008, 02:44 PM   #4 (permalink)
i need help guys
Old 30-12-2008, 03:14 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Buy a Cooler Master 460W, it shud do the trick.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 30-12-2008, 10:34 PM   #6 (permalink)
But all these days my pc was working fine without any trouble .
Old 01-01-2009, 12:54 PM   #7 (permalink)
Also check if it works by changing the SATA Cable.
Make sure that the cable is also not excessively bent.
patkim is offline
Old 01-01-2009, 01:17 PM   #8 (permalink)
The Sorcerer's Avatar
Check boot priority in BIOS before buying anything.
Hardware BBQ
The Sorcerer is online now
Old 01-01-2009, 11:27 PM   #9 (permalink)
Would that prevent the system from starting , i have tried clearing the cmos too
Old 01-01-2009, 11:44 PM   #10 (permalink)
Depends- no harm in checking bios. Trash the power supply in any case. bad power supplies slowly kill the pc and when one notices- its too late. cm 460w extreme plus has efficiency of 70% tested under operational temps of 40 degrees celcius.
Hardware BBQ
Old 03-01-2009, 07:09 AM   #11 (permalink)
I am getting a new power supply soon , 460 w would be sufficient for my pc ?
I lost a hdd with lots of data in it , i dont want to take any more chances
Old 03-01-2009, 10:12 AM   #12 (permalink)
Rubik's Uncle!!
Charan's Avatar
Man you better stay away from computer and buy a typewriter .. jokes apart .. get your computer checked by a professional. You will save lot of time...
Charan is online now
Old 10-01-2009, 03:46 PM   #13 (permalink)
but all day u spend leeping who else would i contact .
got to find some time tomorrow , will get it done at any cost
www.LiveGlamour.com
system not turning on..!!! Pragadheesh QnA (read only) 2 30-04-2007 09:05 PM
WGA Turning Off PCs thunderbird.117 Technology News 2 30-06-2006 08:39 PM
CoolPDF 2.01,turning just about anything into a PDF. rajat22 Software Q&A 2 30-10-2005 09:23 PM
Turning your PC into a Web Server [lokesh] Tutorials 9 21-07-2005 06:54 PM
Turning on DMA suyash_123 QnA (read only) 1 01-02-2005 06:49 PM
- by c4u
