Old 27-12-2008, 05:30 PM   #1 (permalink)
Default HDD problem
hello , i have a 750gb sata 2 in sata 1 mode, p4 3ghz, 2gb ddr2 ram, palit 4670 graphic card . the report of HDD inspector is attached.
it shows that performance, reliability, etc. is degarded and are at 46%.
please tell me how to correct it ?
how do i know the umda version ??
The report was generated by Hard Drive Inspector v. 3.0 Professional (Build # 195)
on Saturday, December 27, 2008 12:04:43 AM.
HDD Information Service v. 3.1 (Build # 347).
System information
Windows version : Windows Vista (Build 6001 : Service Pack 1)
Processor info : 0GHz
Physical memory available to Windows : 2094156 KB (34% usage)
Video settings
Resolution : 1152 by 864 pixels
Color depth : Highest 32 (bit)
Refresh rate : 3145774 Herz
Network
IP Address :
Motherboard
Manufacturer : Intel Corporation
Serial Number : BTCV52400938
Version : AAC83685-205
Computer Name : Rahul-PC
User Name : SYSTEM
User Name : SYSTEM
1) IDE\CDROMTSSTCORP_CD/DVDW_TS-H552U_______________US06____\5&105CE2A0&1&0.0.0
Name: TSSTcorp CD/DVDW TS-H552U ATA Device
Driver installed from C:\Windows\INF\cdrom.inf [cdrom_install]. 1 file(s) used by driver:
C:\Windows\system32\DRIVERS\cdrom.sys (6.0.6001.18000)
2) IDE\DISKST3750330AS_____________________________SD 15____\4&17A85116&0&0.0.0
Driver installed from C:\Windows\INF\disk.inf [disk_install]. 1 file(s) used by driver:
C:\Windows\system32\DRIVERS\disk.sys (6.0.6001.18000)
3) PCI\VEN_8086&DEV_2652&SUBSYS_43568086&REV_03\3&115 83659&0&FA
Name: Intel(R) 82801FR SATA RAID Controller
Driver installed from C:\Windows\INF\oem2.inf [iaStor_Inst_RAID]. 1 file(s) used by driver:
C:\Windows\system32\DRIVERS\iaStor.sys (4.0.0.6211)
4) SCSI\CDROM&VEN_JAFQHM&PROD_5E3C96VC&REV_1.03\5&2C4 F72D4&0&000000
Name: JAFQHM 5E3C96VC SCSI CdRom Device
5) SCSI\CDROM&VEN_JAFQHM&PROD_5E3C96VC&REV_1.03\5&2C4 F72D4&0&000100
Total number of detected HDDs : 1
Hard disk drive # 1
General info
Interface : SATA - fixed
Manufacturer : Seagate
Model : ST3750330AS
Serial number : QK079LJ
Firmware : SD15
Logical geometry info
Cylinders : 16383
Heads : 16
Sectors per track : 63
Physical geometry info
Cylinders : 91201
Tracks per cylinder : 255
Bytes per sector : 512
Capacity available in LBA Mode : 1,465,149,168 sectors (715,404 MB)
Buffer size : 0 KB
Logical drives : C:\; D:\; E:\; F:\;
Total free space : 242,559 MB
Device features
Max block size in R/W operations : 16 sectors
Serial ATA capabilities
SATA Specification Compliance : Yes
SATA Gen-1 signaling speed (1.5Gbps) : supported
SATA Gen-2 signaling speed : not supported
SATA Native Command Queuing : supported
Serial ATA features
Receipt of host-initiated interface power management request : not supported
Device initiating interface power management : not supported
DMA Setup Auto-Activate optimization : not supported
Non-zero buffer offsets in DMA Setup FIS : not supported
Transfer Modes
Supported PIO modes : 0 - 4
Supported Multiword DMA modes : 0 - 2
Supported Ultra DMA modes : 0 - 6
Interface version : ATA/ATA-8
Current transfer mode : SATA 1 (150 MB/s)
Power-on time : 2,793 hours (116 days)?
Min transfer time in Multiword DMA mode : 120 ns
Recommended tr. time in MW DMA mode : 120 ns
Min tr. time in PIO mode without IORDY : 120 ns
Min tr. time in PIO mode with IORDY : 120 ns
Drive features
Temperature sensor detected
Security command set support : supported
Power management support : supported
Write cache support : supported
Read look ahead support : supported
Host protected area support : supported
Microcode downloading support : supported
Enhanced power management support : not supported
Automatic acoustic management support : not supported
Security features
Security erase time : 148 min
Security mode support : supported
Security mode usage : No
Security locking support : not supported
Security freezing support : supported
Security counter support : not supported
Enchanced security erase mode support : supported
Security level : high
Device S.M.A.R.T. status
SMART interface : Physical Drive
Monitoring started at : 12/26/2008 11:58 PM
Last checked at : 12/26/2008 11:58 PM
Reliability : 46% (warning)
Performance : 46% (warning)
Temperature : 79 °F
Drive health : WARNING: Your hard disk seems to be reliable, but some of its important characteristics have degraded.
Death time : not defined
# Attribute Value Thresh Raw T.E.C. date Flags
1 Raw Read Error Rate 114 6 76,515,780 - LC OC PR ER
3 Spin Up Time 94 0 0 - LC OC
4 Start/Stop Count 100 20 492 - OC EC SP
5 Reallocated Sector Count 100 36 0 - LC OC EC SP
7 Seek Error Rate 62 30 180,464,697,949 - LC OC PR ER
9 Power-On Hours 97 0 2,793 - OC EC SP
10 Spin Retry Count 100 97 7 - LC OC EC
12 Device Power Cycle Count 100 20 482 - OC EC SP
184 (Unknown Attribute)_184 100 99 0 - OC EC SP
187 100 0 0 - OC EC SP
188 (Unknown Attribute)_188 100 0 720 - OC EC SP
189 100 0 0 - OC ER EC SP
190 (Unknown Attribute)_190 74 45 470,679,578 - OC SP
194 Temperature: 26 0 60,129,542,170 - OC SP
195 Hardware ECC Covered 43 0 76,515,780 - OC ER EC
197 Current Pending Sector Count 100 0 0 - OC EC
198 Offline Scan Uncorrectable Count 100 0 0 - EC
199 UltraDMA CRC Error Rate 200 0 0 - OC PR ER EC SP
LC-life critical OC-online collection PR-performance related
ER-error rate EC-event count SP-self preserving
rahuljin is offline
Old 28-12-2008, 07:15 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: HDD problem
Are you using a outdated version of that tool ? Coz it's showing your cpu speed 0Mhz.
First run a chkdsk on your HDD & see if it finds any bad sectors.
To be more pecific use hdtune & post the eport
of that soft in here.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 28-12-2008, 02:37 PM   #3 (permalink)
i am using the latest version of HDD inspector. i have checked the website.
hd tune crash each time i run it. it was very difficult to install it too due to crash of setup again and again.
rahuljin is offline
Old 28-12-2008, 05:31 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Well you can install softwares that can give you warning if something is fishy, check out: http://mrintech.com/3-best-utilities...th-at-its-best
- MrinTech :)
mrintech is offline
Old 28-12-2008, 08:48 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
@ rahuljin
Thats strange. I've been using hdtune for exact 2 years.
Have you run chkdsk & got any bad sectors ?
Go to here : http://seatools.seagate.com/
& download a tool called seatools for windows & tell us what it says
topgear is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by c4u
