Old 27-12-2008, 04:06 PM   #1 (permalink)
Smile CPU turns off suddenly
When i switch on the PC, it started with a 'tik' sound and after about 2 or 3 minutes it suddenly turn off by itself with the same 'tik' sound.. I am unable to explain the 'tik' sound .. Its not the Beep sound that i usually heard.. Can anybody help me..
QeeR is offline
Old 27-12-2008, 05:25 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: CPU turns off suddenly
check ur UPS and SMPS and also clean your system RAM. Better go to nearest vendor
- MrinTech :)
mrintech is offline
Old 27-12-2008, 05:27 PM   #3 (permalink)
Cool G5's Avatar
Post Re: CPU turns off suddenly
It can be due to a variety of reasons.
Refer this thread.
Cool G5 is offline
Old 28-12-2008, 09:00 AM   #4 (permalink)
TheSaint
NucleusKore's Avatar
tik usually = impending hard disk head crash
BACK UP YOUR DATA AND GET IT CHECKED
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 28-12-2008, 09:08 AM   #5 (permalink)
AJJU
azzu's Avatar
i tooo had the Similar problem but
after i heard the Tick the System used to Struck totally
Changing The Hdd Cable helped For Me
I love and Live to Design
azzu is offline
Old 28-12-2008, 12:21 PM   #6 (permalink)
a.k.a VipER
Ecstasy's Avatar
Check your RAM.
Check the SMPS and motherboard fan.
Check your cables, sometimes it tends to get loose (even i have that problem).
Hope this helps.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 28-12-2008, 05:45 PM   #7 (permalink)
Evolving Rapidly...
confused's Avatar
dude...it could be that ur proccy is getting overheated.....
my proccy has a limit of 105"....and i had not placed the heatsink properly...so had this same problem.... till i resolved it by fitting the heatsink properly.....
and yeah that sound is simply, ur hard-disk shutting down!!!
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 28-12-2008, 09:09 PM   #8 (permalink)
dude it occurred with me too 1 week ago . it is generaly due to over heating i simply cleaned my pc ( a lot of dust ) with vacuum cleaner ( i was playing my cpu fan passing air with blower and broke it he he he ) and now it is working fine .
frogonfloor is offline
Old 29-12-2008, 11:22 AM   #9 (permalink)
OK! Will check it out.. Thanx for the replies
QeeR is offline
PC switches off Suddenly. Need help ravikanth Hardware Q&A 11 06-12-2008 10:03 PM
Suddenly Restarting Of Pc ajit.naik Software Q&A 6 22-10-2007 05:19 PM
PC has suddenly become sluggish webgenius Software Q&A 3 16-05-2007 08:52 PM
My machine turns Off suddenly aritra Hardware Q&A 5 13-11-2006 09:00 AM
computer turns off suddenly abhishek_sharma QnA (read only) 6 12-07-2005 11:37 AM
- by c4u
