Old 27-12-2008, 06:29 AM   #1 (permalink)
Revolution's Avatar
Question Can't Make Partition Properly.....
please help me !
I am unable make partition(primary,extended.logical) on my new sata hdd.
Currently I have one ide hdd and one dvd-rw.
Revolution is offline
Old 27-12-2008, 07:47 AM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Can't Make Partition Properly.....
If the 232.88 GB is your new hard disk then it already has three partitions. Right click on them to delete them, and then make partitions.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 27-12-2008, 08:10 AM   #3 (permalink)
Revolution's Avatar
Unhappy Re: Can't Make Partition Properly.....
Ahh !
You don't get it.
i have tried that before.
Please watch the pictures carefully.
The new one are showing simple and dynamic not basic.
I want to make primary and logical partition on my new HDD like the older one is showing.
Is that possible or not ?
Old 27-12-2008, 11:13 AM   #4 (permalink)
TheSaint
Yes it is, but you'll have to use a little different approach.
Download this gparted live cd iso (not zip) 94.9 MB
http://sourceforge.net/project/showf...kage_id=271779
and burn it to a cd.
Then boot from it. It is one of the best partition managers I've used.
And better remove all those dynamic volumes and make it all basic
Old 27-12-2008, 12:01 PM   #5 (permalink)
a.k.a VipER
Ecstasy's Avatar
I use 'Partition Magic Pro' and it does the job for me. Even i had a problem where i couldn't make any partitions but this software helped me so check it out. Plus its only 20-25 Mb file.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 27-12-2008, 01:48 PM   #6 (permalink)
TheSaint
^plus it costs ONLY $69.95
Cheap isn't it !
Oops ! I forgot to mention that Gparted is free and open source.
Old 27-12-2008, 02:36 PM   #7 (permalink)
hey...guyz i hav a new toshiba laptop..!!
nd i has only one 250 gb partition...!!
so i want to make 2 more partitions..
so plz help me out in regarding dat..!
chhabra_aniket@yahoo.com is offline
Old 27-12-2008, 03:29 PM   #8 (permalink)
TheSaint
Use Gparted as I have suggested above. You can resize your partitions easily.
Old 29-12-2008, 01:16 AM   #9 (permalink)
why make too many partitions.
create only 3 or max 4 is suff.. too many partitions like a garbage.
i have 3 disk (2 x 80 GB, 1 x 160 GB)
and my partitions
Disk - 1
C:\ 16 GB for Windows
D:\ 55 GB for Softwares
Disk - 2
E:\160 GB for Movies
Disk - 3
F:\80 GB for Videos
Last edited by lucky_chouhan; 29-12-2008 at 01:18 AM. Reason: Automerged Doublepost
lucky_chouhan is offline
How to make a Partition boosters QnA (read only) 7 16-04-2007 05:46 PM
CDs Not Burning Properly. Plz Help. Skud Hardware Q&A 5 24-11-2006 03:13 PM
my sys not work properly mahesu_87 QnA (read only) 3 11-04-2005 05:58 PM
How can I make a new partition?? zeeshan_04 QnA (read only) 6 24-09-2004 08:19 PM
- by c4u
