Old 26-12-2008, 10:57 AM   #1 (permalink)
Pranav Prakash's Avatar
Default My Pc doesn't Starts
Last Time when I closed windows vista, I was not able to start it again as sounds of fans are coming but nothing starts, neither monitor nor cpu. But fans tends to run continously for ages. my system configuration is
hcl 17inch crt monitor
dual core1.8Ghz cpu
intel945gc-m7 te chipset
1gb ddr2 667Mhz ram(umax)
250GB samsung hardisk 80GB western digital hard disk
Pranav Prakash is offline
Old 26-12-2008, 11:17 AM   #2 (permalink)
Answers everything
mmharshaa's Avatar
Default Re: My Pc doesn't Starts
unplug the cable connecting the monitor and the cpu and check whether the monitor is asking for an input..( probably a question mark(?) indicating a socket..)..If this happens there is no problem with the monitor...
Then u need to check ur ram.. whether it is properly inserted.. Try re inserting it and check........
The ultimate solution for all your pc problems: My answer
mmharshaa is offline
PC Starts -> Switches Off -> Starts godsownman Hardware Q&A 10 08-02-2008 08:39 AM
Windows starts physical memory dump every time Skype starts (blue screen of death) mightyboosh Software Q&A 9 20-12-2007 02:42 AM
pc starts but no display mohitgiri Hardware Q&A 9 10-07-2007 03:38 PM
My Pc Starts on second attempt only. Ishan QnA (read only) 2 30-07-2006 01:23 PM
NFS UG2 Crashes as it starts krish Gamerz 3 05-05-2006 11:45 AM
- by c4u
