Old 25-12-2008, 09:07 PM   #1 (permalink)
Exclamation Help mobo driver pb !!!
recently purchased asus p5q pro mobo
installed sp 3
problem is with installing audio drivers
works fine with sp 2
plz hepl guyz
sam1989 is offline
Old 25-12-2008, 09:35 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Help mobo driver pb !!!
^probably the driver cd that came with the mobo does not work well with sp3...download the latest drivers from asus's site here http://support.asus.com/download/dow...Language=en-us
Just select your product and your good to go
My site: collegeclassroom.org
amitash is offline
Old 25-12-2008, 09:40 PM   #3 (permalink)
himadri_sm's Avatar
do you get this error: does not support this operating system: WNT_5.1P
did you try to install by clicking on asus setup?
browse the audio drivers folder in your cd- there must be two folders-32 bit & vista. open the folder 32 bit & click on asus setup. it will install the drivers.
if these don't work try these- Open Regedit and go to :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Windows
find CSDVersion key
100 (hex) means its sp1
200 (hex) means its sp2
300 (hex) means its sp3
Change it from 300 to 200 and restart
Install kb888111.exe (Microsoft UAA Patch)
Install drivers
change the value back to 300 in the previous step
you can download kb888111.exe (Microsoft UAA Patch) from microsofts website.
i have an asus p5kc m/b & i have sp3 installed. my audio drivers install fine.
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline
Old 25-12-2008, 10:29 PM   #4 (permalink)
Smile Re: Help mobo driver pb !!!
thanx a ton sekhar_xxx
it worked
but still have a pb with one driver
high definition driver bus
could you help me with that too
plz
sam1989 is offline
Old 25-12-2008, 11:11 PM   #5 (permalink)
himadri_sm's Avatar
it worked
plz
you're welcome..BTW, what error do you get with that high definition driver bus?please post the error message.anyway, are you getting audio output now? can windows media player play audio files? if everytime you switch on the pc & it starts searching for drivers for new hardware you can do this-1.choose option-no, not this time 2.search for drivers in these locations-browse to folder where audio driver is placed..or you can use the search removable media option if you are installing from cd.3.let the search complete, it will find the drivers,install them.
BTW, if you are getting audio output & you still get this driver searching problem & you are not able to install drivers, then at the end of the above three steps you can check--do not prompt me to install this hardware again..this way windows won't search for drivers every time it boots.but if you are not getting audio output, then do post again with the error message.
Old 25-12-2008, 11:17 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
I had also this problems with realtek HD audio driver.
Just download the latest version 2.11 & your problem will be solved.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 26-12-2008, 12:30 PM   #7 (permalink)
sekhar_xxx
I'm getting the audio o/p but everytime it boots it shows it starts searching for the drivers
thnx for the help
sam1989 is offline
need driver jmsajid Hardware Q&A 9 29-12-2008 10:52 AM
lan driver magneticme200 Software Q&A 17 19-05-2008 08:53 AM
Driver papai_mcc Hardware Q&A 2 20-07-2006 07:24 AM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
- by c4u
