Old 25-12-2008, 07:34 PM   #1 (permalink)
Default Somebody help me plez viewers i need ur help
i have a problem using sata II 500gb hdd with my intel 865gbf(1gb ram,2.8htprosseosr) mobo.... i have two 80gb's ide hard disk install(wrking good).. but when i installed the sata II 500gb hdd it got detected at sata port 0 in bios.. then i did the partions using partion magic 8... i made 1primary and 5 logical partions in 500gb space. I m using this as a storage disk only.. Then i installed windows Xp in one of the ide disk(80gb).. the installation was good and wrked.. but now the problem is tht windows detect the all the partions and drive(including sata 500gb partitions also) but when i try to transfer or copy smthng from sata drives windowxp stalls and gets hang.. why this hapenning.... this true for linux also... why does this happen... i had set jumper seting of sata II to 1.5gbs thn also it not wrking good.. every time i can C my drive but cant operate thm.. PLez frends i knw u can help me me in big trouble from last 5 days
plez just dnt visit leave me fedback me in big trouble guys plez
yess nobody helped me in forum but i got the solution for this thnx aniways if any buddy wants to knw msg and rply
Last edited by dudedevil100; 26-12-2008 at 03:01 AM. Reason: Automerged Doublepost
dudedevil100 is offline
Old 26-12-2008, 06:35 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Somebody help me plez viewers i need ur help
1st run chkdsk to see if your hdd devoloped any bad sectors. Fix them with chkdsk.
If that did not solve your problem then
I think your partions are corrupted.
Delete those partions & create new partions.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 27-12-2008, 02:42 AM   #3 (permalink)
why create 5 and so one...
go for 2 or max 3
lucky_chouhan is offline
Old 01-01-2009, 08:37 PM   #4 (permalink)
actualy i got the solution .. my sata cntrller failed .. so buyed anew sata raid cntrller and my problem is solved thnx for ur feedbacks. now i can extend my hdd capacity to 4terra
Old 03-01-2009, 11:13 PM   #5 (permalink)
Point Blanc
you bought a new card with SATA ports or what,
acewin is offline
How To Change IP? Plez Help.. CHALLENGER Software Q&A 2 21-01-2008 01:01 AM
Hi All Genious, Help Plez CHALLENGER Hardware Q&A 103 03-01-2008 01:16 AM
Numb3rs viewers ... iMav Chit-Chat 11 12-06-2007 12:18 AM
Show Your Signature with viewers IP, Browser, etc... prasanna7287 Tutorials 4 18-12-2006 07:23 PM
Any gamemax viewers? raghu-RAM Gamerz 5 04-02-2006 02:12 PM
- by c4u
