Old 24-12-2008, 04:50 PM   #1 (permalink)
raksrules's Avatar
Default [HELP] Unable to connect 1 PC to another thru LAN cable
I have a desktop machine and a toshiba laptop. The desktop machine has Windows XP while the toshiba lappy has Vista home premium OS.
I am not able to connect the two directly using the LAN cable that i have. The desktop is saying "Connected at 100 Mbps" but the Vista machine says "Limited or No Connectivity". I dont think there is any problem with the LAN card on my laptop because i was able to use broadband connection by connecting the modem to the lappy.
How can i resolve this. I tried pinging them from one another but the request timed out always.
raksrules is offline
Old 24-12-2008, 09:55 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: [HELP] Unable to connect 1 PC to another thru LAN cable
I think you need a cross cable. Go to the nearby computer dealer and get cross cable for LAN.
http://www.duxcw.com/digest/Howto/ne...ble/cable5.htm
This could solve the problem.
desiibond is offline
Old 25-12-2008, 09:42 AM   #3 (permalink)
raksrules's Avatar
i suppose i have a cross cable. I am sure about this because before this lappy i used this windows XP m/c to connect to my old desktop machine which had a d-link lan card and win 98 OS.
Old 25-12-2008, 10:12 AM   #4 (permalink)
jck
omfg noo
u dont need anything just go to tcp/ip settings and put static ip's like:
comp 1 ip: 10.1.1.2
SubnetMask:255.255.255.0
gateway 10.1.1.1
comp 2 ip 10.1.1.3
subnet mask 255.255.255.0
gateway 10.1.1.1
jck is offline
Old 25-12-2008, 10:23 AM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
u neeed to install Link Layer Topology driver in XP.
http://www.microsoft.com/downloads/d...displaylang=en
only after installing this can u create a lan bet XP & Vista systems.
@jck dood from when did a Class A IP (10.1.1.2) start having a Class C subnet mask?
hellgate is offline
Old 25-12-2008, 11:58 AM   #6 (permalink)
To connect 2 pc locally , I dont think the IP-class ranges will matter ,
just give both the same IP range As JCK Mentioned , it will work.... & same subnet and gateway....
___Fr3ndZ___ is offline
Old 25-12-2008, 06:47 PM   #7 (permalink)
raksrules's Avatar
I am not sure about this because there is problem with vista and not xp. Vista is showing limited connectivity by XP is showing that it is connected at 100 Mbps
Edit: Today i tried and both Vista and XP were showing full connectivity but i was not able to ping one m/c from another.
Old 25-12-2008, 11:01 PM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ just install the link layer topology driver once & see for urself.
hellgate is offline
Old 26-12-2008, 02:51 AM   #9 (permalink)
this wat a right thing . do this as per said below.. ur card is not able to aquire a a ip addres under same subnet go on this procedure u will be satified
Originally Posted by jck View Post
omfg noo
comp 1 ip: 10.1.1.2
gateway 10.1.1.1
comp 2 ip 10.1.1.3
gateway 10.1.1.1
dudedevil100 is offline
Old 26-12-2008, 11:28 AM   #10 (permalink)
raksrules's Avatar
^^yes i will try this
But one more thing, after booting into XP on my laptop (it is set in dual mode XP and vista) and setting a static ip for both machines manually i was able to connect both of them
Now its time for Counter Strike over LAN
Connect 2 XP pc's by Ethernet Cable smartygoldenfish Hardware Q&A 4 23-07-2008 10:46 AM
guide to connect laptop n pc using cross cable.. tweety_bird_bunny Laptops and Netbooks 2 05-07-2006 06:35 PM
how to connect dku-5 cable to 6610i bendre123 Mobiles and Tablets 3 22-09-2005 05:34 PM
Reliance R-connect cable prob LG RD2130 a_medico QnA (read only) 1 29-07-2005 02:03 PM
- by c4u
