Old 24-12-2008, 02:25 AM   #1 (permalink)
Default can i buy any modem for my dataone connection?
i subscribe to the dataone 500 plan the last 3 years
i 'bought' my modem as against renting it from bsnl
UT-300R2
recently i bought a netgear wireless router WGR614v7 which is working fine
the power switch in the modem has gone faulty and the modem turns off often
it works if the power switch is pressed hard
bsnl said they cant help me coz i bought the modem and didnt rent it
anyway i think its time to go for a new modem
will any adsl modem work with my connection or do i have to buy only from bsnl?
thanks
contactram is offline
Old 24-12-2008, 08:39 AM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: can i buy any modem for my dataone connection?
yeah it can work...recently I also changed my UT-300R2U modem to Dilnk GLB-502C
VarDOS is offline
Old 25-12-2008, 05:16 PM   #3 (permalink)
Yes, any modem will work.
But don't forget to change the VPI/VCI settings to 0/35 in your new modem if you want it to work with BSNL.
ico is offline
Old 25-12-2008, 10:13 PM   #4 (permalink)
thanks. any suggestions?
Old 26-12-2008, 02:57 AM   #5 (permalink)
no suggestion dude adsl connection is sam for bsnl or any other isp provider... doesnt depends upon the modem u use... go for any good quality (iball) warrented, adsl modem. tensn nahi lene ka bindas karneka
dudedevil100 is offline
Dataone Modem problem.... hsr Hardware Q&A 8 25-07-2008 08:23 PM
Need Help:Hathway Cable Modem,Dataone BB Modem-cum-Router. How to Wi-Fi? awestriker Networking 1 31-01-2008 02:53 AM
Dataone modem for R.S.1 OMG rajas700 Chit-Chat 1 15-06-2007 11:15 AM
Modem for Dataone Chirag Hardware Q&A 1 29-10-2006 02:47 PM
Configuring the Dataone Connection and ADSL modem in SUSE 10.1 Techie_Geek Open Source 2 07-08-2006 10:06 AM
- by c4u
