Old 23-12-2008, 10:09 AM   #1 (permalink)
In the books..Studying
Default Help regarding cooling system
Hey there,
i have got the following configuration in my pc:
Quad core Q6600(O.C 20%)
Asus P5QL-EM mobo
4 GB (2X2 )800Mhz Kingston
Asus Radeon EAH4850
Windows Vista home premium 64 bit
whenever i play games like crysis (on full configuration ie all enthusiast,AAx8,1440x1280..)the game runs fine but the problem is that my graphics case gets heated upto 85 C...So i want to know some good cooling system for my pc...
Price range:3000-4500
Thanks!
-Kanishka
kanishka is offline
Old 23-12-2008, 10:32 AM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: Help regarding cooling system
If you need a aftermarket cooler then look no further than Accelero S1 Rev.2. It's one of the best VFM cooler available in the market. I have got one applied on my 4580 & the idle temps are 43 degrees & load has never crossed 50 degrees. Even after 3 hours of gaming on GTA IV it still loads to only 47 degrees. It costs around 1.6k if you purchase it online & add a 120mm fan to it for extra cooling. That should do the trick.
V for Vendetta
Ethan_Hunt is offline
Old 23-12-2008, 10:35 AM   #3 (permalink)
get a artic cooling solution
Accelero S1 Rev. 2 + Arctic Cooling Turbo Module
http://www.arctic-cooling.com/vga2.php?idx=147
only rev 2 works fine with Hd4850
u can get it from lynx india (make sure its maunfactured after may 2008,else it would not be compitable with Hd4850)
http://www.lynx-india.com/index.php?productID=2031
http://www.lynx-india.com/index.php?productID=2220
also since ur budget is a little high u can go for Thermalright T-Radē
available at lynx again
http://www.lynx-india.com/index.php?productID=3469
again make sure twice that its new versions which is compitable with Hd4850 ..
do let us know ...when u get it..and tell us how it performs...
thats cool ,congrates u bought it .... i was away for a while ..BTW off the topic hows GTAIV and how much FPS u are getting for it ?
chilling.....
imgame2 is offline
Old 23-12-2008, 11:01 AM   #4 (permalink)
Ethan_Hunt's Avatar
^The game is freaking awesome. We have a thread running in the Gamerz section. You might just want to visit it as there is a boat load of discussion going on in there.
V for Vendetta
Old 23-12-2008, 11:06 AM   #5 (permalink)
cool i will be right there
chilling.....
imgame2 is offline
Old 23-12-2008, 03:30 PM   #6 (permalink)
Hey thanks for the suggestions guys.
Asus Radeon HD 4850 has got inbuilt heatsink so how can these help??I mean is it possible to connect 2 heat sinks to a single graphics card?
kanishka is offline
Old 24-12-2008, 12:44 AM   #7 (permalink)
No pain....No gain
john_the_ultimate's Avatar
You'll have to remove your existing heatsink and then install the third party cooling solution.
john_the_ultimate is offline
Old 24-12-2008, 07:47 AM   #8 (permalink)
Ok!!But is thermalright T-Rad better than asus default heat sink??Or has Asus already given better heatsink??Please let me know if anyone knows it....
kanishka is offline
Suggest a PSU & Cooling System pranav1994 Hardware Q&A 3 18-12-2008 09:16 PM
Liquid cooling system salilrane Hardware Q&A 15 04-09-2008 09:26 PM
water cooling system iamitp Hardware Q&A 2 13-04-2007 02:49 PM
CPU Cooling Ishan Hardware Q&A 5 29-01-2006 12:00 AM
cpu cooling ashish_dsc CPU / Motherboards 6 20-05-2005 02:58 PM
- by c4u
