Old 23-12-2008, 06:18 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Default Fan Error on Fujitsu Lifebook S6240
Just a week ago, my fan started to make odd sounds(like it was a scratching noise) when I was playing a game. I restarted the laptop and when it turned on, the BIOS reported that there was an error with the fan and the system was powered off. I can get into the system but I am afraid that the laptop will overheat and catch fire or something. Now the fan is really loud and somehow different. Help!
There is a computer mall around where I live which sells hardware stuff. Though I have never tried to take apart a laptop.
Specs:
Fujitsu Lifebook S6240 3 1/2 years old
Intel Pentium M 1.66ghz
Integrated Graphics
502MB DDR2 SDRAM
Help!!!
update: the laptop gets quite hot when it's charging
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 01-01-2009, 04:14 PM   #2 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Default Re: Fan Error on Fujitsu Lifebook S6240
^ Give it for servicing.
Did the battery get hot prior to the Fan Problem?
My diagnosis.
- Due to some reason/overheating, a wire to the Fan got disconnected; maybe one of the wires which controls the Fan speed.
- Due to Mobo BIOS being unable to control the Fan, its working at full speed, hence the noise.
Many things are manufacturer specific; so making a good speculation is the best one can do.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 02-05-2009, 10:53 AM   #3 (permalink)
I've got the exact same computer, same problem.
For a few weeks, the fan was running full tilt, but I figured that it was just due to age. Then one day it stopped. Now it can't run without a horrible noise, and the temperature can get insanely hot (something along 50 degrees).
I'm really getting worried, because I don't have the money to get it properly repaired. Any suggestions?
11Sharn11 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/105027-fan-error-fujitsu-lifebook-s6240.html
Fan Error on Fujitsu Lifebook S6240 Hardware Troubleshooting Question This thread Refback 10-12-2010 12:59 PM
Fujitsu 6140 ADF Scanner Required..! deepakg Peripherals 1 28-11-2008 06:18 PM
Fujitsu OR Dell ?? snubbed Hardware Q&A 8 03-10-2008 09:03 PM
Fujitsu Laptop snubbed Hardware Q&A 2 14-08-2008 06:13 PM
sheet-fed scanner ? hp or Fujitsu ? mkmkmk Hardware Q&A 3 03-03-2008 09:51 AM
Where to repair Fujitsu notebook in Banagalore Keith Sebastian Laptops and Netbooks 1 22-12-2007 08:26 PM
- by c4u
