Old 21-12-2008, 02:24 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default Dead BIOS
Last Sunday I failed my PC with an OC, since last sunday I am unable to start my PC. I thought that i spoilt the RAM but the RAM is workin fine..Every one is telling that the BIOS is dead
CAN IT BE POSSIBLE? WHAT SHOULD I DO? MY PARENTS DON'T KNOW THIS. CAN MY PC BE RECOVERED? HOW?
Thanks
Varad
VarDOS is offline
Old 21-12-2008, 02:36 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Dead BIOS
What exactly is happening? are the LED's and fans running?..if they are now it mite be a PSU issue. How much did you try to OC by?
Since its a failed OC just remove the CMOS battery on the motherboard for 2 mins and then reinsert it and try to boot...If that doesnt work then disconnect EVERYTHING on the mobo xept cpu,RAM and gfx card....If even that doesnt work, your mobo might be dead and you need to ask for a replacement which means telling your parents.
My site: collegeclassroom.org
amitash is offline
Old 21-12-2008, 05:59 PM   #3 (permalink)
Moral: Don't play if you cant stand your grounds later.
Faun is online now
Old 21-12-2008, 07:36 PM   #4 (permalink)
Intel OCer
amitash's Avatar
BTW are you getting any beeps when you power it up?
amitash is offline
Old 22-12-2008, 05:12 PM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
I am not getting any beeps on startup, nor i was getting any..
The proccy and all the fans r working, also my cathode Ray tube is working also the led on the mobo is working also the DVD/RW Drive can be ejected
There is no beep no display on the screen nor the keyboard light is working
I removed the CMOS Battery for an hour but the problem is still same....
First My RAM latanacy was 5-5-5-15 and I changed it to 4-4-4-12...and since then there is no display and the case as mentioned up is been happening.
VarDOS is offline
Old 22-12-2008, 07:02 PM   #6 (permalink)
Intel OCer
amitash's Avatar
is your RAM working on another computer?...since your keyboard is not recieving any power its an ominous sign of a dead mobo...same thing happened with my MSI Eclipse mobo...everything seems fine but nothing happens.
amitash is offline
Old 23-12-2008, 07:03 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
I've faced exact same problem with xfx 650i ultra mbo to be honest 3 times - so I'll not suggest anyone to buy ( actually any xfx mobo ) it ) 3 months ago thugh I was not ocing.
How did you checked your rams - by plugging it in another mobo ?
Buddy try to use different sticks of Ram.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 23-12-2008, 07:28 PM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
my RAM is working fine on my frnds Intel 945 motherboard....
Also I reseted the BIOS as given in the tutorials on the net...but it didnot worked
My friends and othrs are telling me that the BIOS is dead...what do u think guys???
VarDOS is offline
Old 23-12-2008, 08:43 PM   #9 (permalink)
JAK
What the Heck !
JAK's Avatar
Have u tried clearing the Bios using the Clear CMOS jumper...???
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 23-12-2008, 11:10 PM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
He already tried that.
@ Varad Dilip Choudhari
Yes the bios gone kaput
topgear is offline
Old 24-12-2008, 08:26 AM   #11 (permalink)
15.0 GHz
VarDOS's Avatar
Yeah i have already tried to clear CMOS jumper.
Now what to do??? can BIOS be recovered again or should I go for a new mobo (can't possible)
VarDOS is offline
Old 24-12-2008, 11:32 AM   #12 (permalink)
Intel OCer
amitash's Avatar
IMO you HAVE to get a new mobo...
amitash is offline
Old 24-12-2008, 01:19 PM   #13 (permalink)
15.0 GHz
VarDOS's Avatar
my mobo is still in warrenty period....
VarDOS is offline
Old 24-12-2008, 04:27 PM   #14 (permalink)
Intel OCer
amitash's Avatar
Then just give it to your dealer or the shop you bought it from...they will replace
amitash is offline
Old 25-12-2008, 06:22 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
ya. send it for replacement
topgear is offline
Old 26-12-2008, 08:56 PM   #16 (permalink)
15.0 GHz
VarDOS's Avatar
Yes, did it...
I did the following thing
My frnd also has the same mobo..I took my mobo's BIOS and placed on his mobo while the PC was on..(there is no risk in doing that bcause there is no function of BIOS while we r in windows) and dloaded the latest firmware of the BIOS and installed it on the BIOS...turned off the PC...replaced my BIOS to my mobo and started the PC....IT WORKZ
VarDOS is offline
Old 27-12-2008, 09:24 AM   #17 (permalink)
Intel OCer
amitash's Avatar
^you mean you hotflashed the bios??
amitash is offline
Old 27-12-2008, 09:27 AM   #18 (permalink)
15.0 GHz
VarDOS's Avatar
yeah
VarDOS is offline
Old 27-12-2008, 09:36 AM   #19 (permalink)
paroh's Avatar
Originally Posted by Varad Dilip Choudhari View Post
Yes, did it...
Congrats that ur pc is back
Good work the only problem with hot flash is that if the bios is soldered and u need to de soldered it to take it out it is really a big task to do on the running pc.
can u tell do u need to desolder the bios to take it out and how u take the bios out from ur friend pc(In the running environment) and urs pc.
Or the bios is just inseted in the socket and u remove it and which instrument u used to take the bios out and putting it back??
paroh is offline
Old 27-12-2008, 08:11 PM   #20 (permalink)
Intel OCer
amitash's Avatar
^its very risky doing a hotflash...you might damage your mobo and void your warranty...heres a guide http://icrontic.com/forum/showthread.php?t=25538
I tried toget my dead msi eclipse hotflashed but the BIOS chip was irremovable.
amitash is offline
Old 28-12-2008, 02:30 PM   #21 (permalink)
15.0 GHz
VarDOS's Avatar
I could remove my BIOS Chip Very Easily With a tooth picker
VarDOS is offline
Old 28-12-2008, 02:55 PM   #22 (permalink)
paroh's Avatar
Now this is really a good use of tooth picker
Good job at every step we learn some think
paroh is offline
Old 28-12-2008, 03:07 PM   #23 (permalink)
Real adventure!
V.Prem Kumar
janitha is offline
Motherboard BIOS is Dead... Zangetsu Hardware Q&A 18 05-11-2008 05:42 PM
PC is dead...almost tech_lover Hardware Q&A 10 20-02-2008 11:38 PM
HDD is dead...Help!!! linardni Hardware Q&A 7 30-08-2006 01:01 PM
Is 98 really dead ??????? Help nvidiasingh2006mb QnA (read only) 6 14-02-2006 02:27 PM
Help or i m dead ionicsachin QnA (read only) 6 26-06-2005 03:17 PM
- by c4u
