Old 19-12-2008, 02:30 PM   #1 (permalink)
Default Q6600 problem
So I have a q6600 processor and I have the program coretemp. Each core idles around 36-39c and maxes at around 45c. The problem is that it's showing that it's running at 1596.81 mhz all the time. The computer is about a month old and when I first started using it it went back and forth from 1596.81mhz to the actual speed of 2.4 or whatever. Now it's just stuck on 1596.81. Is this normal? What is going on? I haven't overclocked anything and the voltage is set at 1.325
meinteil11 is offline
Old 19-12-2008, 04:10 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Q6600 problem
^Get into your bios and disable something called intel EIST...that should bring back the multiplier to normal....Its just a power saving feature by intel which underclocks the procy when there is no load...load the procy using prime95 or something and then it will jump bak to 2.4Ghz.
My site: collegeclassroom.org
amitash is offline
Old 19-12-2008, 05:14 PM   #3 (permalink)
Yeah you're right I used prime95 and it jumped to the full 2.4. Thanks
Q6600+thermalright ultra 120 extreme amitash Chit-Chat 3 30-06-2008 02:33 PM
q6600/e8400?? coolest111 Hardware Q&A 76 19-04-2008 12:12 PM
intel Q6600 gapchoo009 Hardware Q&A 9 12-02-2008 08:37 PM
Intel Quad Q6600 gapchoo009 Hardware Q&A 3 28-01-2008 01:12 PM
- by c4u
