Old 19-12-2008, 01:03 PM   #1 (permalink)
I'm in 3D Grafix world!!!
Nithu's Avatar
Question Dual or Single Channel. RAM???
Hi Friends,
I have 2 x 2GB Transcend 800MHz DDR2 RAM. My motherboard doesn't support Dual Channel memory. Is there any problem running in this mode ????
And one more question, if there is no problem then what will be the performance difference between Dual channel and Single channel RAM ????
Thanks....
Intel Q8200 | Gigabyte G41M-Combo | Sapphire Radeon HD 5670 512MB | Transcend 2 x 2GB DDR2 800 | WD 1TB | CoolerMaster Hyper TX3 |
ASUS X53SC-SX536D
Nithu is offline
Old 19-12-2008, 01:28 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Dual or Single Channel. RAM???
No problem, they'll run only not in dual-channel.
There is 5-10% max performance difference, but 4GB of RAM, u dun need to worry much.
Altough g\install a 64bit OS to make max use of ut 4GB.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 19-12-2008, 01:37 PM   #3 (permalink)
Nithu's Avatar
thanks comp@ddict...
ASUS X53SC-SX536D
Nithu is offline
Old 20-12-2008, 09:43 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Anytime
About me:
Old 23-12-2008, 07:38 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
even If your mobo doesn't supports dual channel two sticks of ram give more performance than a single stick ( based on my personal experience )
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 23-12-2008, 08:43 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yeah,they mite, although there is no reasoning cuz the memory conenction remains at 64-bit itself but it may dunno, dual channel gives 128-bit.
About me:
Old 23-12-2008, 11:08 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
Yes buddy. They don't give any significant perf boost. Only 60-100MB higher.
topgear is offline
Old 28-12-2008, 12:13 AM   #8 (permalink)
ruturaj3's Avatar
Question Re: Dual or Single Channel. RAM???
I hav asus M2NPV-VM mobo. with 2 X 512 DDR2 667mhz in dual channel. I want to buy new RAM mostly 2 GB. Tell me which of the following will work.
1) 2 X 512 MB 667 + 1 X 1 GB 667
2) 2 X 512 MB 667 + 1 X 1 GB 800
3) 2 X 512 MB 667 + 2 X 1 GB 667
4) 2 X 512 MB 667 + 2 X 1 GB 800
5) 2 X 512 MB 667 + 1 X 2 GB 800
I want my system should be booting up, even if it is not in dual channel, its fine.
ruturaj3 is offline
Old 28-12-2008, 05:24 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
You want to kkep your 667Mhz ram modules. Any above config you mentioed will work. But if you use 667Mhz & 800Mhz ram module together the 800Mhz ram modules will be runnin at 667 Mhz to maintain the stability.
I would suggest you to opt for 2x 1GB DDR2 800Mhz Ram modules & run them in dual channel. 2GB & 3GB ram has no significant performance diiference in day to day apps even gaming.
topgear is offline
Old 28-12-2008, 09:58 AM   #10 (permalink)
yeah and it is better not to use yamaha yzf r15 to follow a hero honda street..oops got a bit too far with the comparison
realdan is offline
Old 28-12-2008, 02:59 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Buy two 1GB sticks in 667MHz
About me:
1.25GB Single channel vs 1GB Dual Channel 400MHz DDR1 RAM MetalheadGautham Hardware Q&A 15 15-11-2008 09:52 PM
RAM upgrade.. need advice (single channel or dual channel ) g4m3rz Hardware Q&A 3 18-06-2007 08:15 AM
what to do dual channel or single Gaurav Hardware Q&A 2 15-04-2007 12:36 AM
Dual Channel Or Single Channel karthik55859 Hardware Q&A 6 01-08-2006 12:36 PM
Ram for dual channel cyrux Hardware Q&A 3 10-05-2006 08:48 PM
- by c4u
