few days back the drive was opening after 3-4 tries....but today it is not opening...i tried uninstalling the drive still it is not opening ....even when the system is booting i tried at that time also it is not booting...plz solve my problem
"The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila."
How old is ur drive ?
It's a common problem with DVD drives.
If your disc stuck into the dvd drive insert a 2-3inch long pin into a hole in front of the drive. The tray will open. Remove the disc & press gently the tray to close it.
or change the spring of the tray, no change needed until and unless the lens goes caput, if it is able to read and write why change drive, needs just a repair.
There is a circular elastic rubber in the drive may be it is loosen or tight enough. As i also having the same problem the driver rubber is loosen so any one of u know where to get the rubber?
i have the same problem on one of my older sony dvd drives...sometimes it open at other time i have to right click on the drive in my computer to eject the damn tray and when the computer is sleeping and i wanted to boot form disc in that pc then i have to push the tray out physically by using a pin with a handle which came along with the drive..
