Old 18-12-2008, 08:08 PM   #1 (permalink)
Dragon!
jack_the_ripper's Avatar
Default Need a new battery for my UPS.!
hi guys,
i have a proview 500VA ups, working like a charm for the past 5 years(touchwood). But since a few days im not getting backup after power cut. Its beeping continously for about a minute and the PC is switching off.. I guess the battery is dying..
can i change the battery instead of getting a new UPS.! i'd like to know a few 'good' brands.!
thanks!
"Dont walk as if you rule the world.., Walk as if you dont care who rules the world"
jack_the_ripper is offline
Old 18-12-2008, 09:16 PM   #2 (permalink)
Default Re: Need a new battery for my UPS.!
CSB, Panasonic and Indian EXIDE and Chloride.
longlife is offline
Old 18-12-2008, 10:45 PM   #3 (permalink)
Dragon!
can i know the costs?
and is there any specific batteres for 500 VA or 600 VA? i mean can i increase my backup with a high power battery?
Old 18-12-2008, 11:29 PM   #4 (permalink)
Battery is 12Volts rated at 7AH with price range of Rs. 750-600.
Yes, you can increase the backup by putting bigger battery but it wont fit in your UPS case, else you can use it.
neogen is offline
Old 20-12-2008, 07:43 AM   #5 (permalink)
Dragon!
thanks for the replies.! got an exide battery with the same rating, for 600/-.!
New Ups or new Battery? NauticA Hardware Q&A 13 04-07-2008 09:20 AM
ups battery gone, how much does 600va battery cost? fallin_a Hardware Q&A 7 14-01-2008 01:28 PM
Is battery down..?? deepakg QnA (read only) 4 12-08-2007 10:46 AM
- by c4u
