Old 18-12-2008, 07:56 PM   #1 (permalink)
Q6600 Underclocked
sourishzzz1234's Avatar
Question Odd Problem
...hii ..
recently i was experiencing problems with my mobo(MSI)
i changed to abit IP 35E but am experiencing odd problems....
1. i have a sparkle 8500GT 512MB i installed the vista newly but whenever i tried installing the driver (even from other sources than the CD) the next time i boot there is a black screen after windows loads and then in a blue screen it shows dumping physical memory.....and restarts.....
2.... during the post screen when the msgs show like BIOS version etc they are all jabbled up i mean like 512MB RAM is written as 512 M@ RAm the words are displaced.... like version has become quersion etc....HELP SOS
Core 2 Quad Q6600 2.4Ghz (OC->2.7Ghz)
Cooler Master Hyper 212 Plus
aBIT IP-35 E
1*2GB DDR2 800MHz Zion RAM
320GB Seagate Baraccuda
Sparkle nVdia GeForce 9400GT 512MB
sourishzzz1234 is offline
Old 18-12-2008, 08:01 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Odd Problem
Something may be messed up with the cards ROM as its not a mobo problem...Try to get a replacement for it
You may also try to flash the cards ROM...try getting a ROM from somewere and flash using nvidia bios editor
My site: collegeclassroom.org
amitash is offline
Old 18-12-2008, 08:23 PM   #3 (permalink)
The Sorcerer's Avatar
Which power supply? What are the temps displayed in BIOS?
Go to safe mode, disable all start up items via MSCONFIG on run and restart. If it boots up, google for the software called orthos and run it for 5 hours and dont use the pc for that time. If it survives, it was one of the one of those disabled software conflicting with your issue- most probably some drivers. If orthos gives any errors or if it restarts- there are 2 possibility- ram or power supply.
Try booting the pc with a single ram on the first DIMM slot. If it doesnt work, swap the first ram with the second and put it on the first DIMM slot. Give it a shot again. If it doesnt than most probably both the rams died. Why both rams died- 2 reasons. Manufacturing defect- sometimes they come as soon as they are on and sometimes it takes ages. I rather would have used transcend than zion. The second is that power supply has fried your rams. If this is true, its a good thing it didnt fry your hard drives.
Let us know once you have progressed.
Hardware BBQ
The Sorcerer is online now
Old 18-12-2008, 08:33 PM   #4 (permalink)
Q6600 Underclocked
Question Re: Odd Problem
RAM i don think so.....for am able to work on it...am sending these msgs frm my comp only....the jabbled up words r only there during booting untill the OS select menu is shown.....
aBIT IP-35 E
Old 18-12-2008, 09:42 PM   #5 (permalink)
Intel OCer
amitash's Avatar
i thought of conflicting processes first but that doesnt explain the crap hes getting during POST so i think its the card BIOS issue...To be safe use driver cleaner pro to remove all drivers, then install nvidia drivers and give it a go...And since he can work on the comp i really cant see any RAM issues...Maybe some strong electromagnetic disturbances damaged the card....Was the card working fine on the older mobo? if so it mite also be a mobo issue...try flashing your mobo to the latest BIOS
EDIT: you can get latest BIOS for your mobo here http://www.abit.com.tw/page/en/downl...ET_TYPE=LGA775
amitash is offline
Old 19-12-2008, 08:09 AM   #6 (permalink)
Q6600 Underclocked
No i experienced the same problem with the older mobo also..... for flashing the card please can u provide me the details and the firmware......
aBIT IP-35 E
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by c4u
