Old 17-12-2008, 07:06 PM   #1 (permalink)
Exclamation i cant keep max res in 9500gt!
having palit 9500gt ddr2 512mb, with lcd monitor viewsonic va1926w 19"inch
i can only keep 1440*900 only cant i keep it higher, i have seen others for more than that is it possible?
iyuvabharat is offline
Old 17-12-2008, 07:15 PM   #2 (permalink)
Query Killer!!!!!!
max_snyper's Avatar
Default Re: i cant keep max res in 9500gt!
Dude the monitor u are refering has max resolution 1440*900,
there is no "problem" in the system or ur monitor!!!!
max_snyper is offline
Old 17-12-2008, 07:40 PM   #3 (permalink)
hey maxy my friends tell me it depends on graphic card is it true or as u say only as per monitor
Old 17-12-2008, 08:16 PM   #4 (permalink)
dOm1naTOr's Avatar
ur monitor has the optimal resolution at 1440*900 which is specified by the manufacturer. There are some monitors 19" which can also use 1680*1050 too, which has somewhat 2 native resolutions.
btw ur card has the max res of 2560*1920, but it ll be limited as per the type of monitor u are usin.
usually for CRTs, there are no optimal resolution thing, so u can go much higher if u can bear the low refresh rates. And LCDS luks much worse on non-native resolutions higher or lower.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 18-12-2008, 01:30 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Tell those friends they r fools and just listen to ^^^^ "dOm1naTOr"
About me:
http://about.me/preetam_nath
comp@ddict is offline
4670 vs. 9500gt TheLetterD Hardware Q&A 54 28-11-2008 12:44 PM
- by c4u
