In our room we have a computer and a laptop. The laptop has bluetooth and I bought a USB bluetooth dongle for my system. I am able to transfer files between the two.
We have 'You connect ' internet connection for the laptop .
Now , how can I connect both the systems in LAN and share the internet connection between the two ?
I have vista and xp in laptop and xp in desktop.
I tried the above procedure in laptop in xp and not able to connect.
I cannot follow The above said procedure in vista as the options are different.
Actually , I have a bluetooth dongle for my desktop (xp). It created a connection 'bluetooth network' in the 'Network connections'.
My laptop (Vista) has inbuilt bluetooth .There is a connection 'Local area connection 2 (Bluetooth personal area network)'in Network connections.
Now is it possible to connect these two systems in LAN ? How ?
I connect to internet (you tele conection ,Ethernet based) in laptop using 'Local area connection' and 'you connect' .
Now can I share this betweeen the two systems ? How?
I tried the above procedure but not able to connect properly.
In Laptop
Local area connection 2 (Bluetooth personal area network )-- properties-- ipv4--propreties
IP adress 192.168.0.1
subnetmask 255.255.255.0
default gateway 192.168.0.2
preferred DNS server 192.168.0.2
In desktop
Local area connection -- properties-- ipv4--propreties
IP adress 192.168.0.2
default gateway 192.168.0.1
preferred DNS server 192.168.0.1.
The connection in Desktop shows connected but in laptop it shows 'not connected'.
What to do?
If I am not clear in my question ,plz let me know and will tell my problem clearly.
thank u
Anyone help me plz......
Reason: Automerged Doublepost
