Hi
I hav SONY DVD RW AW-G170A drive on my pc running XP SP3. It does everything right except reading the DVDs, it reads some DVDs though, only 1 out of 10.
And when checking on another pc (my friend's) running Vista, it reads all the DVDs .
I don't understand where the problem is? I hav finished reinstalling drivers and even XP but the problem remains.
Any solution guys...
if i remember correctly..this is the model i once owned and didnt last one year..with low usage..got it exchange under warranty for a new piece....as far as i can remember this model is a defective one..
since you said that in xp it cant read a lot of dvds..you might be interested to see if you can claim warranty and get a replacement
but then as you have said it works well on vista pc..
make sure......
it isnt the cable that is causing the problem..
you check the power cable also..or the power requirement of the PC
you could also try flashing it and you can always flashed it back to the original version if it has no effect on it..
Thanks!
i cannot exchange it as it is out of the warranty period. anyway, i will try flashing it with the updated firmware. the power might not be the problem, as it reads some dvds, cds and writes well.
can anyone tell me, the flashing of firmware, updates the drivers in OS or the drive itself? can this damage the drive to scrap?
It updates the drive itself. the site you need is:
liggydee.cdfreaks.com
binflash.cdfreaks.com
I tried it around last year, and it worked perfectly after that.
thanks dheeraj.
from liggydee.cdfreaks.com, i couldn't get the right firmware for SONY RW AW-G170A.
i downloaded a firmware from binflash.cdfreaks.com but the version is not updated one it seems. it is v1.45a and the current version of my DVD drive is 1.62. is it fine to flash with this one?
