Old 14-12-2008, 05:15 PM   #1 (permalink)
Default Need help urgent!
I need a power supply for-
intel Q6600
ASUS p5n-e sli
XFX 8800gs
3 ddr2 ram
2 hdd SATA
2 DVD rw
4 120 mm fan
so which should i get cm 600/650 or zebronics 600/700(don't know the price)
price limit 5-5.5k
i prefer CM 600 exteme power but i don't know if it will be enough?
need to buy in 2 days
kuki_295 is offline
Old 14-12-2008, 05:20 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Need help urgent!
CM-600 ought to be more than enough...It easily handled my Q6600 OC to 3.1Ghz and 3870x2 with 2 HDDs and 2-90mm fans, 2-180mm fan and one 250mm-fan
My site: collegeclassroom.org
amitash is offline
Old 15-12-2008, 02:19 PM   #3 (permalink)
Ok i'll buy the cm-600W thanks for reply.
kuki_295 is offline
*Urgent* Mobile shipping problem *Urgent* navino87 Buying Advice 1 13-11-2008 07:16 PM
Need Urgent Help pranavrules QnA (read only) 4 30-06-2008 01:54 PM
Need Help???very Urgent smile Software Q&A 4 14-11-2007 12:01 AM
Very Urgent:Pls Help sandeepkochhar Software Q&A 3 11-09-2006 02:29 PM
Well is My RAM 333 Mhz Help!!!URGENT!!!! abhinav QnA (read only) 17 29-04-2005 08:49 PM
