Old 14-12-2008, 10:33 AM   #1 (permalink)
Default Need Intel Core 2 Quad Q9450
I want to purchase Intel Core 2 Quad Q9450 so pls tell me where it is available. If Q9550 is in good price then i purchase it.
vaibhav55 is offline
Old 14-12-2008, 10:36 AM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: Need Intel Core 2 Quad Q9450
14K
damngoodman999 is offline
Old 14-12-2008, 02:27 PM   #3 (permalink)
It is new Box Pack ? and how i purchase it.
Old 14-12-2008, 02:28 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
Where do you live?
http://twitter.com/akshayms
nvidia is offline
Old 14-12-2008, 02:31 PM   #5 (permalink)
kota , rajasthan
Old 14-12-2008, 02:33 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
^^I dont know shops there, but it should cost you less than 15k for that processor.
nvidia is offline
Old 14-12-2008, 02:35 PM   #7 (permalink)
no problem. can u arrenge for me ?
Old 14-12-2008, 02:37 PM   #8 (permalink)
-----ATi-----
nvidia's Avatar
^Remove your number dude..
I don't think i can arrange a deal for you. If you are willing to buy online then try www.theitwares.com
nvidia is offline
Old 14-12-2008, 02:45 PM   #9 (permalink)
Can u arrange Q9550 ? Q9450 is not on site
Old 14-12-2008, 02:46 PM   #10 (permalink)
-----ATi-----
nvidia's Avatar
Nope..
nvidia is offline
Old 14-12-2008, 02:48 PM   #11 (permalink)
ok. i have board Intel DQ45CB. it is good or not
Old 14-12-2008, 09:46 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Okay okay.
Well, as for Q9550, u'll get it from techshop.in
They''ll send it to ur house
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 17-12-2008, 02:34 PM   #13 (permalink)
but it costly on site
Old 17-12-2008, 02:39 PM   #14 (permalink)
Intel OCer
amitash's Avatar
You can get Q9550 from lynx-india.com home delivery too..its nearly 17k though
My site: collegeclassroom.org
amitash is offline
Old 17-12-2008, 02:41 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
THen get it from lynx-india.
About me:
Old 17-12-2008, 02:43 PM   #16 (permalink)
it is secure to buy
Old 17-12-2008, 02:50 PM   #17 (permalink)
Intel OCer
amitash's Avatar
^yes it is...call them for more details
amitash is offline
Old 17-12-2008, 02:57 PM   #18 (permalink)
it is total 18k on site
Old 18-12-2008, 02:14 AM   #19 (permalink)
Point Blanc
check locally, if you know any good shop and they can bring it in the proccy well and good. Because most of things in Kota would be coming from Delhi, which will cost less than any of the online sites.
acewin is offline
Old 18-12-2008, 01:17 PM   #20 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Or just go for a Q6600. Y want the Q9450? It's phased out. Any specific reason?
About me:
Old 18-12-2008, 09:46 PM   #21 (permalink)
Point Blanc
12 MB cache, is a good reason, is a good performance boost, thats what I see in reviews against Q9400. Then again if he can spend as much as 14K, then why Q6600 which has heat issues even Q8200 will be good or Q9300, and if can go as high as Q9550 then little more would be core i7
acewin is offline
Old 19-12-2008, 12:21 AM   #22 (permalink)
At Hell's Disq
hellgate's Avatar
@vaibhav55 if u want a Q9450 or Q9550 then i cud arrange 1 for u.
btw if u havent bought mobo already or if u can return it then better go for Core i7 920.why spend 17k on a LGA775 procy when u can get a i7 920?
hellgate is offline
Old 19-12-2008, 10:23 AM   #23 (permalink)
pls arrange Q9450 or 9550 for me
Intel Quad Core and Motherboard nktonu CPU / Motherboards 3 29-09-2008 02:55 PM
Intel D915GAV or Intel Core 2 Duo / Core 2 Quad...!!! sunandoghosh Hardware Q&A 52 14-08-2008 02:49 PM
When will Intel Core 2 Quad Q9450 be available?? confused Hardware Q&A 10 04-04-2008 06:38 PM
Intel Core 2 Quad reviews hit the net naveen_reloaded Technology News 7 05-11-2006 11:12 PM
Intel ships first quad-core Core 2 Extreme QX6700 sabret00the Technology News 4 15-10-2006 12:14 PM
