Old 14-12-2008, 12:54 AM   #1 (permalink)
Be The Best
fordac's Avatar
Arrow Which SMPS should i buy???
Hi friends, i am here with another question. I need to buy a branded SMPS as i have power problem in my system. First of all my system configuration below
Intel Core2Duo @ E4500 2.20GHz
4GB 800Mhz Transcend DDR2 RAM
320GB SATA HDD + 80GB SATA HDD
GeForce 7300 GT 256MB card
Lite-On 20X DVD Writer
Zebronics Standard 450W SMPS
Zebronics Antibiotic Cabinet
3 FANS Available by default in the Cabinet
Front panel Display (Powered by Watch/DVD player battery separately)
The problem that i experience is that my DVD writer says a weird POWER CALIBRATION ERROR while writing DVDs and CDs. So i gave it for a support check who told that it works fine. And to my surprise it did work like a brand new writer in one of my friend's system (He uses a Zebronics True power 450Watts SMPS). But when i put it on my system the same error occurs again. So i pretty much confirmed that it got a power problem so i need you to suggest me a nice SMPS. My budget is 3.5K.
Intel Core2Duo @ E4500 2.20GHz,
Intel DG33FB Motherboard,
GeForce 9800GT 1GB DDR3
17" Flat LG E700S CRT Monitor
fordac is offline
Old 14-12-2008, 01:00 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Which SMPS should i buy???
^^ power calibration error got nothing to do with the psu.
if you using xp open Control Panel and Administrative Tools -> Services then search for "IMAPI CD-Burning COM Service", Right-click on it and select properties and disable startup type. Worked for me.
If you still want to change your psu- nothing beats corsair vx450w for 3.9k. 33 amps on +12v rails and 80% efficiency rate.
Hardware BBQ
The Sorcerer is online now
Old 14-12-2008, 01:04 AM   #3 (permalink)
Be The Best
fordac's Avatar
Arrow Re: Which SMPS should i buy???
Thanks but i use Windows Vista Ultimate X64 and i need to know whether Cooler Master SMPS is good or not because it is around 3.5K. Thanks again in advance.
fordac is offline
Old 14-12-2008, 01:14 AM   #4 (permalink)
^^ There are many reasons you get power calibration error. Update your driver's firmware to be sure. Majority of the disks we get in India are sub standard and trash. Try writing disks on 4x speed.
If you still want to change your power supply regardless- cm460w if you are on a lower budget. cm extreme 600/650w- is not 600w- not even on 100% peak load. Maybe it pulls 500w from the wall but I am sure it doesnt give out 500w in peak load. Amps on +12v rails and efficiency are same between cm460w and cm 600w. But cm 460w is of newer model than cm 600w. cm extreme 600/650w is obsolete and approx 1k more than cm 460w so it doesnt make sense spending so much on it. Its either 18 amps and 70% efficiency based cm460w or a meaty 33 amps with 80% efficiency based corsair vx450w. Google for the reviews- corsair vx450 is a highly decorated power supply.
Hardware BBQ
Old 14-12-2008, 08:39 AM   #5 (permalink)
corsair 450VX is the thing for you.
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
Blackfire is offline
Old 14-12-2008, 05:49 PM   #6 (permalink)
Be The Best
fordac's Avatar
Thumbs up Re: Which SMPS should i buy???
How much does it cost????
Hey buddy i tried the firmware update also but it didnt help. Also i bought a Genuine sony DVD and CD to make sure about the crappy low quality disk but it was the same. As i have already mentioned it works pretty well with my friend's computer.
Am planning to change my graphics card also to PALiT 9800GT 1GB DDR3 so will the cooler master 460W be enough for my system.
fordac is offline
Old 14-12-2008, 07:30 PM   #7 (permalink)
bro i think it costs around 2750
Old 14-12-2008, 08:05 PM   #8 (permalink)
Corsair vx450 costs 3.9k! coolermaster 460w costs 2.5k.
Hardware BBQ
Old 14-12-2008, 09:49 PM   #9 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Coolem Master EXP 500W costs 2.6k AFAIK.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 15-12-2008, 04:36 PM   #10 (permalink)
Be The Best
fordac's Avatar
Do you where i can find this in Chennai. I know i can fin this in Ritchie Street but is there any specific shop where i could find it at the price which you have quoted???
fordac is offline
Old 15-12-2008, 06:52 PM   #11 (permalink)
dOm1naTOr's Avatar
9800GT as uve mentioned need lotta power. Its wise to go for 55nm 9800GTX+ for 12k or ATI HD4850 for 8.5k. i recommend the latter. CM EP 600w for 3.5kwud be a nice investment, although VX450 is somewhat enuf.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 15-12-2008, 06:58 PM   #12 (permalink)
^^ lol a cm extreme so called 600w is just 18 amps on +12v rail with just 70% efficiency. corsair vx450 is 33 amps on +12v rail with 80% efficiency. There's not much difference between cm 460w and cm extreme 600w. But cm 460w is a better buy than cm 600w anyday as its cheaper and its newer than cm extreme 600w. Corsair vx450 is in its class of its own. Even a grade lower component based cx400 corsair is 30 amps which costs 3.5k can whoop cm 600 extreme.
If the OP is on a budget- cm 460w. Even a Powersafe 500 gold can do around 18 amps on 70% efficiency rate. If he can spend more there's always corsair vx450. But cm 460w is enough for this rig.
Hardware BBQ
Old 15-12-2008, 07:32 PM   #13 (permalink)
Exploring
ravikanth's Avatar
In chennai you dont have CM 500w ExPSU.
CM 600w ExPSU @ RS.3800 and Corsair vx450 @ Rs.4050 is available at Delta Pheriperals, Ritche St. I bought corsair vx450 2 weeks back
ravikanth is offline
Old 15-12-2008, 08:05 PM   #14 (permalink)
dOm1naTOr's Avatar
btw EP600w employs dual +12v rails each at 18A. Surelly Corsair VX uses exceptional quality components and CM EP [real power if far better] series, but even 80% effiency out of 450w is less compared to 70%efficiency out of 600w.
choose EP if u wanna run more devices at comparatively lower price. If u have the money, go for VX.
G3: XPS M1530 |
FZ 16.
Old 16-12-2008, 12:12 AM   #15 (permalink)
Dual rail is just one rail split into 2. Its pretty common sense now that coolermaster extreme power 600w is a seventeam 500w OEM. Its done because this way the power distribution can be stable and coolermaster can comprimise on quality of capacitors, wires, cooling etc.
Hardware BBQ
Old 16-12-2008, 04:34 PM   #16 (permalink)
Be The Best
fordac's Avatar
Guys i am technically weak in the SMPS part, also dOm1naTOr has said that for the PALiT 9800GT 1GB DDR3 the CM 500W is not enough. Now it way too confusing for me whether i should spend extra or could i find a better one at 3.5K.
Will it be better if i buy the CM 600w ExPSU which costs only Rs.300 Extra as per my budget???
fordac is offline
Old 16-12-2008, 06:41 PM   #17 (permalink)
Exploring
ravikanth's Avatar
CM 600w ExPSU (2 years warranty) = Corsair vx 450 (5 years warranty)
Now you decide yourself.
You will bring home a relatively inexpensive power supply that even though is sold as being a 450 W unit can deliver up to 570 W at 48º C – in fact Corsair could have easily labeled this power supply as a 500 W unit, but they preferred to stay on the safe side.
Source: http://www.hardwaresecrets.com/article/540/10
Old 17-12-2008, 12:13 AM   #18 (permalink)
Be The Best
fordac's Avatar
Wow that is really helpful. The reason i was constantly sticking to 500W is because i checked the PALiT website and under the 9800GT 1GB DDR3 card they have mentioned that the card requires a min of 500W PSU to operate. Now I guess i have to look on the performance rather than cost. I guess i have to opt for Corsair 450W VX Thanks for the help.
fordac is offline
New SMPS anubisX Hardware Q&A 6 09-10-2008 10:22 PM
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
About SMPS Adhip007 Hardware Q&A 8 01-12-2005 01:14 PM
SMPS / PSU... samanvya_ad Hardware Q&A 8 14-11-2005 01:16 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
