Old 12-12-2008, 08:56 PM   #1 (permalink)
In the books..Studying
Default Motherboard For around 8K-9K
Hey People,
Please suggest me a good motherboard for around 8k-9k
My other configurations are:
4 GB (2x2 ) 667 Mhz
Quad Core Q6600
Seagate 500 GB HD
Asus Radeon HD4850 .
I want a good Mobo for gaming.
I have seen this Mobo : Asus P5QL-EM
Please let me know if it is good.
Thanks
-Kanishka
kanishka is offline
Old 12-12-2008, 09:46 PM   #2 (permalink)
Default Re: Motherboard For around 8K-9K
i think P5Q-Pro/P5Q-E should be a good choice for your budget range.
check the below review links for your reference:
http://www.overclockersclub.com/revi...p5q_pro/11.htm
http://www.cpu3d.com/review/4924-1/a...roduction.html
dhanraj is offline
Old 13-12-2008, 08:15 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
MSI P45 Neo-F for 5k is more than enough.
desiibond is offline
Old 13-12-2008, 08:35 AM   #4 (permalink)
Asus P5Q-Pro
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
Blackfire is offline
Old 13-12-2008, 10:34 AM   #5 (permalink)
The Sorcerer's Avatar
Gigabyte GA-EP31-DS3L for Rs. 3,200. p45 boards are just another slighty updated version of p35. It doesnt make sense the present chipsets for LGA775 is just slight update. x48 is the updated version of x38 and p45 is updated version of p35. These chipsets have reached their prime and their limit, so it doesnt make sense to spend so much on a motherboard. Gaming is more on the graphic card than on the motherboard. Pretty shocked that members didnt tell you this.
Hardware BBQ
The Sorcerer is online now
Old 14-12-2008, 07:02 AM   #6 (permalink)
Point Blanc
Asus P5QL-EM, is G45 chipset mobo, check for P45 chipset mobo.
as desibond said MSI P45 Neo-F is quiet good option.
You can also check its variant Neo2 and Neo3 as per your choice of specs.
acewin is offline
Old 14-12-2008, 10:30 AM   #7 (permalink)
damnbadman666
damngoodman999's Avatar
ASUS P5Q pro great & only 8800/- , great board for OCing Q6600
damngoodman999 is offline
Old 14-12-2008, 12:23 PM   #8 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
are the other components yet to be bought or have you already bought them ? If former, get Q8200 instead of Q6600 and get 800MHz RAM instead of 667 MHz RAM. Net price difference would be 0, but you get much better OCing capabilities and less power consuption.
For mobo, I suggest a good CrossFire capable board.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 14-12-2008, 05:11 PM   #9 (permalink)
but bro Q6600 is more Overclockable than Q8200?. but i support for 800MHz ram
Old 14-12-2008, 07:19 PM   #10 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ i dont think so cuz Q8200 is 45nm afaik
also for mobo u can get MSI P45 Platinum
hellgate is offline
Old 14-12-2008, 09:03 PM   #11 (permalink)
damnbadman666
Q6600 is very old quad , but doing something good in performance but not like other quad 45nm processor ,
Q6600 u can OC to 3 to 3.2 on stock , but the power consumption will be more and more
Old 15-12-2008, 12:38 PM   #12 (permalink)
The Smaller Bang
Q6600 is NOT more Overclockable than Q8200.
At defaults, it consumes similar (but higher) power, has higher clockspeed and double cache.
So it looks highly attractive then.
But when overclocking, Q6600 drinks power, and still can't reach the levels Q8200 can reach, finally making Q8200 BETTER than Q6600 after moderate overclocking of both to same limits of temperature and power.
If you already have a mobo, that too an intel mobo, then Q6600 is the only choice since they can't OC. But never make the mistake of buying a non OC board as you will regret it not now, but after 3 years, when the warranty period would have expired and better CPUs arrived in the market, when you realize that with a Rs. 2000 cooling solution, your PC can perform as good as the new rig digit reviewed.
24 pin Motherboard & 20 pin PSU pratik03 Hardware Q&A 7 02-04-2008 05:56 AM
CPU + Motherboard tharkiman Hardware Q&A 3 20-01-2007 07:24 PM
how to look which motherboard shivi4 CPU / Motherboards 2 31-07-2005 01:01 AM
