Old 12-12-2008, 08:15 PM   #1 (permalink)
Default prices of Gigabyte X38-DQ4 & ASUS Maximus Formula & Foxconn X38A
Can anybody tell me what are current prices of these three motherboards?
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
Blackfire is offline
Old 12-12-2008, 10:55 PM   #2 (permalink)
darklord's Avatar
Default Re: prices of Gigabyte X38-DQ4 & ASUS Maximus Formula & Foxconn X38A
There is no board as Gigabyte X38 DQ4, its either DS4 or DQ6
Foxconn board is not available locally.
Asus Maximus Formula is 18k or so.Maybe less but not less than 15k
darklord is offline
Old 12-12-2008, 11:14 PM   #3 (permalink)
Intel OCer
amitash's Avatar
^My dealer quoted the maximus formula at 13.5k
My site: collegeclassroom.org
amitash is offline
Old 13-12-2008, 12:16 AM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ wat happened u again shifting to LGA775 or something?
if ur dealer is giving that mobo for 13.5k then get it asap.its steal at that price.
hellgate is offline
Old 13-12-2008, 08:11 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
seriously, why should one pay 14k for core2 based board when Nehalem's boards are available for 2k more and that the processor too is available for 15k. Just a thought.
desiibond is offline
Old 13-12-2008, 08:33 AM   #6 (permalink)
ok bro i may have posted wrong so what is the price of Gigabyte X38 DS4?
Old 13-12-2008, 10:42 AM   #7 (permalink)
The Sorcerer's Avatar
I suggest you save money and/or buy nehalem config. It doesnt make sense spending so much money on an LGA775 board now. It wise to wait for sometime and buy the x58 board with nehalem core with some good 1066 mhz rams. With some bios updates in the future, you can buy and use beyond 2000mhz based rams.
Hardware BBQ
The Sorcerer is online now
Old 13-12-2008, 12:00 PM   #8 (permalink)
but bro DDR3 cost bomb right now plus X58 motherboard are costs much more than X38 plus the nehalem will also costs much more than Q6600 which i plan to buy & plus right now there is no performance difference between i7 & quad core.
bro can you tell me prices of i7 processors & a good X58 board? if they suits me i can consider them
Old 13-12-2008, 12:29 PM   #9 (permalink)
^^ That isnt a good reason to spend so much on a DDR2-LGA775 based motherboard now is it? Most People barely tweak settings like dram-fsb ratio, voltages, northbridge and southbridge. You have to look at price per performance ratio as well.
Hardware BBQ
Old 13-12-2008, 12:37 PM   #10 (permalink)
so what components do you suggest?
Old 13-12-2008, 01:41 PM   #11 (permalink)
Intel OCer
amitash's Avatar
Lol no way would i shift back to LGA 775...I have already ordered the Gigabyte Extreme board...I was just giving the price for the maximus formula my dealer quoted thats all
amitash is offline
Old 13-12-2008, 03:11 PM   #12 (permalink)
bro can you tell me the price of your motherboard, processor & memory?
Old 13-12-2008, 03:40 PM   #13 (permalink)
I would recommend waiting for a month's time. We should get better rams by q1 2009. It make sense that we should get atleast 2000mhz if someone wants to move. Too much latency is not worth it.
Hardware BBQ
Old 13-12-2008, 03:54 PM   #14 (permalink)
so you mean that i should change Ram to DDR3 but should stick to Quad core? right
Old 13-12-2008, 04:54 PM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ You should move to Nehalem or wait for Deneb. No offense meant, it will be really really stupid to pay 15k for X38 motherboard at this point of time.
Old 13-12-2008, 06:19 PM   #16 (permalink)
^^ you are right. The whole platform is changing from ddr2-ddr3. With that kind of budget- its wiser to wait. Waiting for one month wont hurt if you ask me.
Hardware BBQ
Old 13-12-2008, 08:00 PM   #17 (permalink)
Intel OCer
amitash's Avatar
Gigabyte GA-Ex58 EXTREME (Ordered arriving in a week)--20k
i7-920--299$ (bought in the US)
G-skill 6GB 3x2GB--240$
amitash is offline
Old 13-12-2008, 08:04 PM   #18 (permalink)
what prices do you expect after 1 month?
Old 13-12-2008, 09:10 PM   #19 (permalink)
^^ Better ram options. He can save some money till that time as well.
Hardware BBQ
Old 14-12-2008, 08:33 AM   #20 (permalink)
thank bro
ok!!! it looks like that i have to wait.
bro when will you are expecting i7 price to be under 10K ?
Old 14-12-2008, 11:54 AM   #21 (permalink)
^^ Doubted. Too early to say. As it is there are always delays for price cuts to be reflected in India- especially Mumbai.
Hardware BBQ
Old 14-12-2008, 02:46 PM   #22 (permalink)
Point Blanc
guys have a question about RAM for setting a nehalem 1 GM RAM is good enough or not I mean if a person can setup by spending minimum in RAM it is good enough so that RAM can be added latter, bcoz again, 4GB sticks havent hit in the market. MAX RAM will be reached then only as 4 DIMMs
acewin is offline
Old 14-12-2008, 04:47 PM   #23 (permalink)
i gb ram is enough for surfing or working on word, excel & some multimedia experience but except to play games or run heavy duty software on it.
Old 14-12-2008, 05:14 PM   #24 (permalink)
Intel OCer
amitash's Avatar
Ya 1GB will be enuf for most small time apps and DONT get 4GB of RAm...either get 3 or 6 as nehalem as a tripple-channel mem controller which gives a HUGE performance boost...Also make sure that the RAM you get has a voltage of less than 1.65v or you will burn your processor..Tri-channel kits arent available in india AFAIK but you can get the transcend RAM which costs about 2.5-3k for 1GB and has 1.55v
amitash is offline
GIGABYTE vs ASUS Spat - Apology by GIGABYTE ? shadow2get Random News 2 16-06-2008 04:44 PM
ASUS Rampage Formula - Intel X48 Chipset capt.rej Reviews 18 05-05-2008 09:22 PM
MSI or ASUS or GIGABYTE debasish13 Hardware Q&A 6 24-11-2006 08:04 PM
Asus vs Gigabyte sAr QnA (read only) 12 30-10-2004 08:33 PM
