Old 10-12-2008, 12:31 PM   #1 (permalink)
Exclamation Expert Advice Required
What is the performance difference between ram DDR2 667mhz and DDr2 800mhz ???
How much is the performance difference between PM45 mobo and PM965 mobo ???
Which is a better configuration performance wise?
P7350 proc +PM45 mobo +3 gb RAM 800 mhz or T8100 proc +PM965 mobo + 3 gb RAM(667 mhz) ?
Is the performance difference significant ?
tom.vipin is offline
Old 10-12-2008, 01:37 PM   #2 (permalink)
Default Re: Expert Advice Required
the basic difference in the ram is this
one works at a higher frequency that the other ie one can run at 800mhz while the other can only run at 667.
afaik this only makes a diff with the kind of processor you have
if u have some processor running at 667mhz no point in buying ram running at 800mhz
cause then the ram will also be working only at 667
btw in your case both of those processors are over 1k Mhz so i guess it would be better to go with the 667Mhz..
all of the above are just my views..
im so gonna follow this to see what some expert has to has about this
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
fuzzz is offline
Old 10-12-2008, 03:42 PM   #3 (permalink)
Point Blanc
P7350 is 2GHz and 1066 FSB proccy and T8100 is 2.1 GHz and 800FSB proccy.
PM45 vs P965 motherboard comparision.
RAM FSB comparision
Well P7350 is a real mobile processor, alot more cooler and energy efficient than T8100, speed is not the only thing which counts.
PM45 is newer mobo chipset and alot much better than P965.
For RAM FSB nothing much is needed to be said, if the RAM FSBs would have been also interchanged still the first one would have been better, because of better chipset and proccy.
acewin is offline
Old 10-12-2008, 04:30 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
No second thought. And btw, what is the difference in price?
desiibond is offline
Old 10-12-2008, 06:38 PM   #5 (permalink)
I was thinking of buying a new laptop. The decision is between XPS1530 and HP Pavillion DV5-1015tx.
XPS-60K
HP-65K
Which one should i go
Old 10-12-2008, 11:54 PM   #6 (permalink)
Point Blanc
dv5-1015tx ftw
acewin is offline
Advice required skippednote Chit-Chat 9 26-06-2008 09:32 PM
Expert Advice Needed !! coolboy_n Software Q&A 12 07-03-2007 01:40 PM
need ur expert advice guys... nishant71 Mobiles and Tablets 5 16-04-2006 03:06 PM
[size=18]Connecting CD-Writer - Expert Opinion Required[/siz harishkp QnA (read only) 4 18-02-2005 10:12 PM
AGP Upgrade Suggestions/Advice Required ChetK QnA (read only) 22 01-08-2004 07:29 PM
