Originally Posted by Cool G5
Contrast ratio is overhyped term these days.
The word Dynamic is a misnomer. Even a monitor having a 10,000:1 dynamic contrast ratio won't be able to beat a monitor having a true contrast ratio of 700:1.
Read more about Contrast ratio
Which one is better?
E900WA
Screen Size19" WideResolution1440x900(WXGA+)Pixel Pitch 0.283Brightness300 cd/㎡Contrast Ratio700:1Response Time5ms Display Area408.24x255.15(mm)Display Colors16.2 millionViewing Angle160/160 (L/R;U/D) (CR>=10)Input SignalsD-sub / DVI-DHorizontal Frequency (KHz)31 - 83 (KHz)Vertical Frequency (Hz)55 - 76 (Hz)Video Bandwidth (MHZ)25 - 135 (MHz)Color TemperatureReddish/Normal/Bluish/User modePower Consumption45W (max)Power SupplyBuilt-inFeaturesSenseye+Photo
VIsta Premium Certification
Kensington Lock
VESA wall mounting 100 x 100 mmAdjustments (UP/DOWN)Tilt -5/20 (down/up)Dimensions (WxHxD)391.6x448x179.4(mm)Weight3.78 kgAccessories (Standard)Quick start guide
User manual CD
VGA, audio cableEmission StandardTCO'03
or
G900HDA
Screen Size18.5"ColorSilver black / BlackResolution1366 x 768Pixel Pitch 0.3Brightness300 cd/m2Contrast Ratio1000:1(Dynamic Contrast Ratio 10000:1)Response Time5msDisplay Area409.8x230.4 (mm)Display Colors16.7 millionViewing Angle170/160Input SignalsD-subHorizontal Frequency (KHz)30 ~ 83Vertical Frequency (Hz)50 ~ 76Video Bandwidth (MHZ)25 - 135Color TemperatureReddish / Normal/ Bluish /user modePower Consumption30W (max)Power SupplyBuilt-inFeaturesSenseye+Photo Technology
5ms Response Time
16.7 Million display Color
HDCP CompliantAdjustments (UP/DOWN)Tilt -5/20 (down/up)Dimensions (WxHxD)443.7x342.3x165 mmWeight3.6 kgAccessories (Standard)VGA cableEmission StandardTCO'03Vista CertificationBasic
I payed 8000rs for G900HDA.
Its is getting replaced by
E900WA, and i have to pay 450 rs more.
Is is Worth folks?
