Old 10-12-2008, 12:00 PM   #1 (permalink)
Default LAN lights blinks every now and then
Hi
I just installed ubuntu 8 (from december 2008 digit dvd) as a second OS in my comp with xp sp2. But now when I am using internet in ubuntu, the LAN lights blinks for 5 minutes and then stop blinking completely. Same with xp.
I have another computer with vista. Both these computers are connected to a hub with star topology, and I am using BSNL ZTE modem, which is also, obviously connected to the hub. Internet working fine in the other computer, the problem is only with the dual boot PC, although I suspect it has anything to with the problem.
So how do I get the lan working.
Thanks.
shakunim is offline
Old 11-12-2008, 11:37 PM   #2 (permalink)
Default Re: LAN lights blinks every now and then
try reducing the link speed to 10M full/half mode...
dhanraj is offline
SMPS Indicator Blinks !!! anubisX Hardware Q&A 4 10-10-2008 10:44 PM
My screen blinks........... zebanon Hardware Q&A 2 17-02-2008 01:13 PM
My screen blinks... zebanon Software Q&A 1 11-02-2008 10:26 PM
PC does not starts....beeps+blinks navjotjsingh Hardware Q&A 3 17-07-2006 02:10 PM
UV Lights somebody !!! mohit Hardware Q&A 5 15-11-2005 07:58 PM
