Old 09-12-2008, 07:44 PM   #1 (permalink)
RMN
Default Should i always D/C my HDD?
im using my old laptops IDE HDD with my desktop via USB.my Q is..should i always use the "Safely Remove Hardware" option when i shutdown my PC?
becouse i would like to keep it plugged in all the time.
tq
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 09-12-2008, 10:31 PM   #2 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Default Re: Should i always D/C my HDD?
No - no need. Windows takes care of all that while shutting down. Some times back i also used HDDs via USB without any prob. Only take care while switching off the HDD. Also switch off the HDD after ur comp shuts down.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 10-12-2008, 08:19 AM   #3 (permalink)
RMN
thank you
you mean unplug?couse i don't have any option to turn it off!
RMN is offline
Old 16-12-2008, 03:38 AM   #4 (permalink)
The Frozen Nova
casanova's Avatar
Yup.
www.nerdweed.blogspot.com
casanova is offline
