Re: which upgrade 2 do ?
i dont really see get why you would recommend an upgarde of Gfx card amitash.. i mean seeing as how 8800gt is more that capable to taking care of the gaming needs (med-high) for some time to come
basically the problem is that the mobo in possesion which btw is 965 not 945 run at a max fsb of 1066 . the proceessor installed is a dual core 2.66 running at 533mhz
all the new proccesors come with an fsb of 1333 atleast the good ones do
now my recomendation to you would be to get a new motherboard for now. yes there will be no performance increase .
then get a new proccy . with a new proccy installed the performance increase will be quite good
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
