Old 08-12-2008, 07:55 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default Help Upgrading The Rig
Hi I am helping my friend to upgrade his RIG..
His current rig is
Pentium 4HT 3.4GHz
865 Chipset
128MB of RAM
40GB HDD
His budget is 6K and he want to upgrade his mobo, RAM, HDD....can u guys pls suggest a upgrade within 6k which will support Pentium 4 System.....
ThankYou
Varad
VarDOS is offline
Old 08-12-2008, 09:36 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: Help Upgrading The Rig
lol... the best he can do is save up and collect atleast a sum of 15k to upgrade this.
E2180/ASUS P5K PLVM/2Gb 667MHz RAM/HD4650 = 12.5k.
Psychosocial is offline
Old 08-12-2008, 11:22 PM   #3 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
6k is not the amt of money to upgrade min 10~11k required to upgrade.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 09-12-2008, 12:08 AM   #4 (permalink)
Point Blanc
max he can do is upgrade in RAM and HDD,
Varad you are short in description of processor(3.4GHz, but what pin types and how old is system). Mobo upgrade is not worth.
If anything like celeron or Dual core is also proposed it will become more than 6K.
For HDD and RAM upgrade he should check in the prices and then decide on his own.
Though he can get a mobo for 478 pin from MSI or Asus (intel 945 chipset based mobo) will cost 2.2-2.5K, its kinda worth as will give you option of SATA and DDR2 RAM. Other than that you do not have any option
Instead of asking here you should check in the market for prices.
I really do not know why are you scared of googling little bit. Check ITwares site for littlie pricing info.
acewin is offline
Old 09-12-2008, 10:55 AM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
2day i will get his system screenshots of CPU-Z
VarDOS is offline
Plz help me in upgrading my pc jith Hardware Q&A 4 24-06-2008 08:14 PM
Help me in upgrading my PC! reshadat Hardware Q&A 5 22-10-2007 10:07 AM
upgrading old p3 help please tamalsen Hardware Q&A 6 04-10-2007 09:52 PM
upgrading .......... salilrane Hardware Q&A 7 17-12-2006 08:25 PM
Plz Help me in upgrading my PC!!!!! vasukibk_bangalore Hardware Q&A 2 13-01-2006 10:01 PM
