Old 07-12-2008, 10:22 PM   #1 (permalink)
Unhappy Hard disk problem
Hi guys, whenever i am turning my pc on a message appears on screen
" hard disk status bad backup and replace" What does it mean????????
my pc is running fine ......... help......
dixit8611 is offline
Old 07-12-2008, 10:59 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: Hard disk problem
B4 doing anything else, backup ur important data.
Then run "chkdsk" in all the drives.
Report back.
The symptoms r not good.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 08-12-2008, 12:07 AM   #3 (permalink)
Default Re: Hard disk problem
it is time for repalcement.
akiso is offline
Old 08-12-2008, 01:12 AM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
if u hav warranty remaining on ur hdd then RMA it asap.
ur getting SMART failure prediction.
hellgate is offline
Old 08-12-2008, 01:51 AM   #5 (permalink)
Smile Re: Hard disk problem
I have finished disk checking and the problem disappeared.......thanks for help ..........everything is running fine and smooth........
Old 08-12-2008, 11:33 PM   #6 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
still the prob may be der. For total HDD checkup use "chkdsk <drive> /r"
Using the option '/r' will scan all the sectors(used+free) of ur HDD and will also check for bad sectors , partition table integrity , mis-reported free space , and will try to recover corrupt data.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 09-12-2008, 12:00 AM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
Check out: http://www.techsupportalert.com/best...ng-utility.htm
- MrinTech :)
mrintech is offline
Hard disk problem maddy_in65 QnA (read only) 2 14-10-2008 08:44 PM
Problem With DVD? or Hard Disk? or Something Else thetillian QnA (read only) 3 29-06-2008 11:36 AM
Hard Disk Problem valtea QnA (read only) 4 14-06-2005 07:15 PM
hard disk problem Techmastro QnA (read only) 1 02-06-2005 11:46 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
