Thanks for the replies friends. I am very busy this week so don't really have time to research on your suggestions immediately.
Originally Posted by acewin
you never gave your budget, so would not suggest much, except will wait for your response on your budget.
Actually I did mention it , Acewin, in INR. It translates to ~ 300 USD. As I mentioned, I am open to stretch beyond that if it's worth it, but after a good amount of convincing myself.
For your work, a Quadcore would be good. and if you are spending good worth then intel core i7 especially if you can wait for couple of months so that prices become little stable. Core i7 run only on DDR3 RAM
Yeah, the i7 looks like the dream engine but my motherboard is already down and my sister needs to use a PC so I can't wait for more than a week. Which QuadCore is a good balance of price and perforamce? What do you think about the Phenom? I hope my budget is not too modest for my requirements
Both Acewin and Power_user_EX have suggested against IGP so I've begun to think in terms of an external GPU. Also that'll allow me a gradual upgrade so that I can spend the bucks on a good CPU and motherboard as of now.
DDR3 being so pricey I think it makes sense to go with DDR2 now. But can I use a DDR2 together with a DDR3 (retaining all benefits of the DDR3) if I buy one later? And any suggestions for a mobo brand? Thanks again for being so helpful!
