| Forum |
#1 (permalink) |
win2k intrnls xpert
What is the significance of dual-channel memory? Is there any performance problem if I install 6 GB of memory on 3 of the 4 slots ?
Hell is the impossibility of reason. |
#2 (permalink) |
At Hell's Disq
yes u can use 6GB of ram on P45 Neo-F.
though to use that ram u need to install a 64bit OS and only 64bit apps can use that much of ram.better go with 2*2Gb ram.latencies will be better than 3*2GB setup. Dual-Channel mem setup provides double the bandwidth (128-bit) than single ch (64-bit)
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#3 (permalink) | |
Alive Again...
MSI P-45 Neo-F Supports 16GB Memory see this http://www.msicomputer.com/product/p...Neo-F&class=mb but take care of your OS http://www.microsoft.com/whdc/system...ae/paemem.mspx yes what hellgate said is absolutely right go for 2x2gb i.e. 4GB instead of 6GB
! जय हिंद ! Proud to be INDIAN Last edited by satyamy; 07-12-2008 at 12:44 AM. Reason: Automerged Doublepost |
#4 (permalink) |
Point Blanc
go for 2x2GB and not 3x2GB, why because this mobos supports 4GB RAM single stick, let them be in the market and then buy them, in htat way your money will be saved. besides why you need 6GB
#5 (permalink) |
Searching for Anti-Matter
Dual channel works twice BUT ONLY PAPER! Practically its almost same as single channel says the test result frm Tom's Hardware.
To use full 6GB of ram u need a 64-bit OS coz 32 bit OSes uses addresses which are at max 32 bits long i.e 2^32=4 GB max addressable mem in a 32 bit OS.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| memory upgrade for Intel 845GLAD motherboard | sree01 | Hardware Q&A | 10 | 23-10-2007 08:52 AM |
| How to increase shared memory in D102GGC2 motherboard? | sunny_sigara | Software Q&A | 3 | 03-09-2007 12:37 AM |
| Asus motherboard with built-In DDR3 Memory Modules | john_the_ultimate | Technology News | 8 | 10-07-2007 10:33 PM |
| how to increase vedio memory of motherboard (by sharing ram) | bkpeerless | CPU / Motherboards | 4 | 30-10-2005 04:46 PM |
