| Forum |
#1 (permalink) |
I want a high end system which can support 3 - 4 Virtual Machines(at least 2 gigs of ram allocated to each VM) simutaneously. I would like to start with 8 Gigs of RAM but with an option to upgrade in future. I am also totally confused on 1. The type of cooling solution that I would need. 2. The power supply unit requirements for such a machine. I would appreciate if someone can provide info on what should be the config that I should choose(Processor/MotherBoard/RAM/HDD/PSU/Cabinet). Your inputs are greatly appreciated. Thanks, Anuj |
#2 (permalink) |
Point Blanc
Virtualization performance increases with the number of cores.
And you would like atleast like 2 HDDs(as per suggestion of what I had read for virtualization) on which OS do you wanna run your virtual machines. not sure if there is anything like better motherboards for especially virtualization. Have you tried to run any virtual machine on any system earlier. and have knowledge about it. Please share your infos. |
#3 (permalink) |
I am planning to use Win2K8 64 bit or Linux 64-bit as my base OS.
Yes, I have used Virtual PC/Virtual Server and VMware (on Linux and Windows). What I am looking for is to select a Motherboard with a clear upgradability path(in terms of RAM). I was wondering Intel's S5000XVN but the board itselt is costing more than 25K plus. Regards, Anuj |
#4 (permalink) |
Point Blanc
bro you are talking about server based setup, Xeon processors and motherboard for same
I hope when you are talking about win2k8, I hope you got registered OS, if that is the case you can think alot many things. Last edited by acewin; 06-12-2008 at 07:06 PM. Reason: Automerged Doublepost |
#5 (permalink) |
Yes,Win2K8 is a proper licensed version. I am just looking out for possiblities that I can have for me to start with a system with 8 Gigs of RAM and be able to add more RAM in future. I am also hoping to limit my system cost to under 75K for now.
So, what is your take on the config that I would need to go for. |
#6 (permalink) |
At Hell's Disq
if u want future upgradability then its best to go with Core i7 920 based rig,u'll be able to upgrade to 24Gb of total sys ram if reqd.also u can upgrade cpu if reqd.
but cost will be very high.it overshoot ur 75k budget. only mobo,procy & 6Gb of DDR3 will cost u bout 50k (mobo will be MSI X58 Platinum for 17k).
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Xen Virtualization | The Unknown | Open Source | 7 | 31-08-2008 12:44 PM |
| Virtualization - impact of virus | eagercyber | Software Q&A | 2 | 01-05-2008 07:52 AM |
| Virtualization in Linux: Parallels virtualization software is now available in Ubuntu | subratabera | Open Source | 10 | 14-02-2008 11:40 PM |
| Sun's new virtualization manager supports Windows, Linux | CadCrazy | Technology News | 2 | 17-11-2007 09:00 AM |
| Microsoft cuts Windows virtualization features | morpheusv6 | Technology News | 2 | 15-05-2007 04:56 PM |
