Old 04-12-2008, 05:30 PM   #1 (permalink)
Default Strange problem...have to remove and put back Laptop battery for it to boot.
hi,
I am experiencing a strange problem. When I try to power ON my laptop nothing happens...no LED, no fan ,HDD sound. As if the Laptop is dead.
However when i connect to AC adapter works fine.....seems like a battery issue.
But when i remove the battery and put it back laptop works fine. Is it only some loose contact issue (though i dont think so coz battery fits snap tight and Laptop is only 6 months old.)
And it doesnt happen each time...only after a week or so.
Has anyone experienced something like this? Please share.. Any advice is useful.
Thx.
pramodv1988 is offline
Old 04-12-2008, 05:33 PM   #2 (permalink)
Default Re: Strange problem...have to remove and put back Laptop battery for it to boot.
Contact points clean? Try cleaning them
ThinkFree is offline
Old 04-12-2008, 05:45 PM   #3 (permalink)
thx for the quick reply.
Cleaning with a dry clothe right? will do that.
Tips and Tricks that you never thought existed www.cooltechtrix.blogspot.com
Old 04-12-2008, 05:52 PM   #4 (permalink)
Yes, must do.
Strange Boot Problem? evewin89 Software Q&A 3 17-04-2008 12:21 PM
Dell Laptop Poor Battery Problem paid Laptops and Netbooks 1 30-11-2007 10:55 AM
strange problem with CMOS battery ondemandemails Hardware Q&A 4 22-11-2007 12:14 AM
OSes don't boot :: Strange problem rohan Software Q&A 7 03-08-2006 11:24 AM
