| Forum |
#1 (permalink) |
GO through this link....... http://www.pcworld.com/article/11677...mory_flaw.html Plz help me.... |
#2 (permalink) |
that link was in 2004..would that apply to your new laptop?
you could try going to power option in control panel and turn off all power saying options..and also disable hibernate if it is enable then report back what happen..
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va |
#4 (permalink) |
This sort of thing used to happen with my friend's PC . It would hang only when kept idle.....more specifically when not using the mouse or keyboard. He tried many things....nothing worked. Reinstalled OS and its fine now. Give that a try in case nothing else works.
Tips and Tricks that you never thought existed www.cooltechtrix.blogspot.com |
#5 (permalink) |
First of all, thks for da reply guys
@realdan - i have switched off all power saving options disabled sleep hibernation and even screensaver,etc.....still it hangs.... @thinkfree - yea, only ctrl+alt+del button works after it hangs....only thing u can do is open task manager.....but i didnt c the running processes.....ill giv that a try....... @pramodv1988 - exactly da same problem here too ....reinstalling OS is a pain ...in HP laptop u cant partition the hard in d away u want.....my 320gb HDD is just havin 2 drives..... once with OS and all stuff... and other 20gb drive for backup&recovery....So if i hav to format and reinstall, i hav to write all my datas (its arnd 150Gb) in dvds and then copy everythin again back.........is der ny other way to come out of this problem....... TEMPORARY SOLN: if im running some programs like media player or winamp (mutin the sound), it doesnt hang....but as i mentioned its just a temporary soln.....i want to get rid of the prob permanently.....SO please help me |
#6 (permalink) |
^^Find the process which is making ur pc hang or else reinstall the OS. No other option seems to be there.
Tried safe mode? Does the problem appear here as well? |
#7 (permalink) |
SAFE mode.......can i do that?.....can i keep my computer in safe mode waiting for it to hang?......wont it damages any windows files if it HANGS?.....at first, ill try to check the running processes.......
#9 (permalink) | |
The software/driver download link for your model is here.http://h10025.www1.hp.com/ewfrf/wc/p...&lang=en&cc=us Last edited by j_h; 06-12-2008 at 02:34 PM. |
#10 (permalink) |
Guys i found da problem......Its due to skype......it all started only after installing skype....i just started uninstalling the softwares from the period this problem startd......then when i uninstalled skype, my lappy became normal again.....But i cant understand da reason.......is skype not compatible with vista?.....nyway im happy now....thks guys for the help....
@ j_h - ill do that one ......infact i hav install all the updates available der........thks |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Does your PC use its idle CPU/GPU cycles to fold? | bhanja_Trinanjan | Chit-Chat | 2 | 07-11-2008 09:42 AM |
| Will a laptop hangs at customs department | harikatt | Laptops and Netbooks | 12 | 04-01-2007 06:31 PM |
| ABC torrent is idle | manishji | Software Q&A | 3 | 12-09-2006 01:52 PM |
| How to change the idle time?? | grinning_devil | QnA (read only) | 3 | 19-04-2006 01:52 AM |
| System idle process | saurya_mishra | QnA (read only) | 2 | 10-02-2006 05:23 PM |
