Old 03-12-2008, 01:23 AM   #1 (permalink)
Default Upgrading 1 yr old PC, mainly used for gaming
Hi to all,
I have AMD 4400+ proc, Asus M2A-VM mobo, 2x1GB transend 800Mhz ram, XFX 8600GT, 20" LCD. My main use of PC is for gaming. Got this PC in nov 2007. I am planning to upgrade Gfx card to improve gameplay. what shud i do? budget around 10k. dont have another PCIe slot on mobo, so cant add another 8600gt in SLI !!!
shud i wait for some new products to launch ???
tushargupta is offline
Old 03-12-2008, 03:31 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: Upgrading 1 yr old PC, mainly used for gaming
If your PCIe Slot is 2.0, then you can go for either nVIDIA 9XXX Series or ATi 4XXX or 3XXX Series, else you would have to settle down for nVIDIA 8XXX or ATi 2XXX Series
techtronic is offline
Old 03-12-2008, 07:59 AM   #3 (permalink)
RMN
for 10K you can get Palit HD4850.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 03-12-2008, 11:08 AM   #4 (permalink)
Cool Buddy's Avatar
You should upgrade your processor as well, your mobo supports AMD athlon X2 processors. go dual core for better performance.
AMD Phenom II X4 840, 4 GB RAM, MSI HD5670, Corsair CX400 PSU
Nokia 5230
Canon IXUS 115 HS
Cool Buddy is offline
Old 03-12-2008, 11:20 AM   #5 (permalink)
4850 obviously. I suppose yours is a single core processor. Let it be for the time being. Start saving money so that when you have more cash Phenom II will be released which is rumored to be on par with intel quads so that you may expect nice price cuts from both sides so that you can later decide which processor to buy.
dvijaydev46 is offline
Old 03-12-2008, 11:53 AM   #6 (permalink)
Ethan_Hunt's Avatar
Errrr... Main question before we go all gung ho about the graphic card. Which PSU do you have? Better not leave that out if you have a sub-standard one right now.
V for Vendetta
Ethan_Hunt is offline
Old 03-12-2008, 03:51 PM   #7 (permalink)
thanks for all the replies
how do i check whether my PCIe is 2.0 or not? i have a asus m2a-vm mobo. i have glacial 400 watt psu. i have 2 internal sata hdds also. will my psu be able to handle 4850? proc is amd x2 4400+. shud i upgrade my proc also?
pls guide.
Old 03-12-2008, 04:45 PM   #8 (permalink)
Check your motherboard manual (I don't think it is 2.0)
Certainly not
I would wait till march.
Old 03-12-2008, 06:26 PM   #9 (permalink)
thank dev,
i guess will wait till next summers, save some more money and do a complete system overhaul. i have one more doubt. on installing games on 64 bit xp on my system, the games were installed in 'program files x86' folder in c drive. will the applications or games installed in this folder run in 32 bit mode and if so how to make them run in 64 bit mode.
Old 03-12-2008, 06:39 PM   #10 (permalink)
GeekyBoy's Avatar
You can run newer cards, coz PCIE 2.0 is backward compatible with the older PCIE version, although performance might be a bit lower.
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Plz help me in upgrading my pc jith Hardware Q&A 4 24-06-2008 08:14 PM
To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse debasis_7012005 Hardware Q&A 24 10-09-2007 02:37 PM
what's the difference btwn Online gaming & Internet gaming singh Gamerz 2 12-08-2006 12:03 PM
Helppp me in UPGRADING my "Dumb" PC 2 a &$Gaming P.C$$ kunwar Gamerz 14 15-06-2005 10:38 PM
Can small gaming companies suceed in todays gaming market Charley Technology News 16 03-03-2005 10:56 PM
