Old 02-12-2008, 03:46 PM   #1 (permalink)
Default CPU & Processor Mini-itx Under 4.5K ?
Hello i would like to know a CPU+PROCESSOR = 4.5K
i was looking for D945GCLF2 but i am unable to find it in mumbai. Please provide contact information if it is avialble and rates too....
Can any one suggest me a piece like that
My needs are only a Low end HTPC and download rig...
blackbird is offline
Old 02-12-2008, 04:01 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: CPU & Processor Mini-itx Under 4.5K ?
You can either get an Atom based solution (for low power (as in electricity) usage) costing 3.5K for Atom 1.6GHz CPU + 945GC motherboard, or you can go for a powerful dual core setup, with nVidia GeForce 7050 chipset based motherboard for 2.1K and an AMD Athlon X2 4400+ CPU for 2.5K which can actually PLAY some games at low resolutions.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 02-12-2008, 04:31 PM   #3 (permalink)
Actually i already said that D945GCLF2 is not yet avialble if it is than please give me the contact...
regarding amd
theitwares.com
EVGA 112-CK-NF72-K1 nForce 610i/7050 1066 FSB Rs. 2925
Asus P5N MX Nvidia GeForce 7050 1333 FSB Rs. 2375
Zotac NF610I-C-E - Value nForce 610i/GeForce 7050 1333 FSB Rs. 2300
Palit N73V 7050/MCP73V Chipset 1333 FSB Rs. 2375
Asus M2N - VM DVI Nvidia GeForce7050PV/nForce630a(MCP68PVNT) Rs. 3175
Asus M2N - VM HDMI Nvidia GeForce7050PV/nForce630a(MCP68PVNT) Rs. 3800
Amd Processor Under Budget
Athlon X2 4400 Not available
Athlon 64 X2 4600+ 2.4GHz 1MB L2 cache 2700
Sempron LE 1200 2.1 GHz 256KB L2 cache 1600
Sempron 3200+ 1.6GHz 256KB L2 cache 1400
I can build a power Machine with AMD + GeForce7050 but will it be Mini-ATX ?
I really need a Mini itx Mobo because i will move the machine now and then....
Any body knows where can i get Intel D945GCLF2 Motherboard
http://www.intel.com/products/deskto...2-overview.htm
Old 02-12-2008, 05:39 PM   #4 (permalink)
The Smaller Bang
^^do you have another PC ? if so, please KEEP SEARCHING for D945GCLF2. Paired with Transcend 2GB DDR2 667MHz RAM for 1.3K, it will be a killer looow power PC.
and yeah, 7050 SHOULD be available in Mini ITX. If not, get 780G along with Sempron 2.1GHz (added advantage of allowing smooth upgrade to Deneb after 6-9 months). If you underclock sempron to 1GHz, its should be below intel solution in power consuption.
Help needed to buy mini-ITX MB and Processor sundaramkumar CPU / Motherboards 1 06-06-2008 05:28 PM
02 xda mini Angad singh Mobiles and Tablets 2 19-03-2008 10:46 AM
Processor Name??????Big Question.1 Processor 3 Names vutonium Hardware Q&A 12 05-07-2007 11:07 PM
mini cd vignesh QnA (read only) 11 05-06-2005 02:34 PM
