Old 01-12-2008, 10:41 PM   #1 (permalink)
99.9% Idle
axxo's Avatar
Default What UPS for 22" LCD?
I currently have a microtek 1KVA ups with the power switch broken today. Its also not working properly to the fluctuations hence I want to go for a new one.
Will a 600VA do suffice for a PC & 22" LCD monitor? Also I cant afford to go beyond 3k. Kindly suggest one, its urgent as am going to get one tomorrow.
Unban praka123
axxo is offline
Old 01-12-2008, 11:51 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: What UPS for 22" LCD?
600VA can easily handle 22" lcd
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 02-12-2008, 12:34 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: What UPS for 22" LCD?
you can easily get 1KV UPS for 3K
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 02-12-2008, 02:53 PM   #4 (permalink)
99.9% Idle
axxo's Avatar
Thank you guyz..digged this forum a lot for the same query and found APC to be the preferred brand and 650 VA more likely to do well for this setup.
1KV from APC retails around 7k, while the cheaper ones like microtek are poor to withstand any fluctuations and moreover the build quality is very poor.
Anyway I bought 650VA UPS from APC today for 3.1k from delta peripherals chennai. Hope this will be the best for my pc&monitor.
Unban praka123
axxo is offline
Old 02-12-2008, 05:27 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
Yes, APC is the Best in UPS, APC 650 VA will work fine and do all wht you need
satyamy is offline
Old 02-12-2008, 06:57 PM   #6 (permalink)
Even I have APC 650 - bought from Delta and it's good. It comes with powerchute software with which you can do a managed shutdown when there is no ac power and you can also turn off those irritating beep sounds.
dvijaydev46 is offline
Old 02-12-2008, 08:31 PM   #7 (permalink)
99.9% Idle
axxo's Avatar
Just now got it installed, wow the ups is awesome so as its software that monitors & gives status abt voltage fluctuations, errors etc. Also shows battery charging status, available time and so on.
unfortunately ups load is not yet completely utilized by my pc components
Unban praka123
axxo is offline
"How Office 2007 "Exposed" Bill Gates" rhitwick Random News 15 03-09-2008 12:09 AM
Microsoft "new" patent could "force" downloaders to view commercials!! Hitboxx Technology News 17 28-12-2007 09:06 PM
NEW VIRUS GIVING MESSAGE:"Can not find script file"WIN32.DLL.dll.vbs" ". mdp Software Q&A 5 02-10-2007 02:11 PM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
"INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers CannedLizard Hardware Q&A 4 29-07-2006 12:47 AM
