Old 01-12-2008, 09:21 PM   #1 (permalink)
KrishPuri.com
Default Buying a new MOTHERBOARD and PROCESSOR upto 25k??
Hi Guys,
I am thinking of buying a new motherboard and processor. My budget is upto 30k. If this is less, I can buy them 1 at a time.
I need a very high performance processor and motherboard. It will be required for all sorts of purposes...
I currently own a XFX nVidia Geforce 8600 GT GPU with 512 mb memory. I also own a 320 GB HDD and 2 GB RAM. Regarding the display, I recently bough a Dell SP2208 WFP widescreen 22" LCD monitor.
Which is the best Intel Core 2 Extreme?? How much does it cost?? I know that is very costly but how will it be if I go for an Intel Core 2 Quad processor?? What other processors are there that perform equally well?? What motherboard should I use with these processors??
Please answer my questions and also suggest me your opinions on different motherboards and processors that are equivalent to these...Also, please quote their prices.
Cheers
Krish
Processor: Intel Core i7 920 @ 4 Ghz
Motherboard: Intel DX58SO Extreme
Graphic Card: MSI R6950 Twin Frozr III Power Edition/OC
Memory: G.Skill RipjawsX 16 GB DDR3 @ 1666 Mhz
Storage: 5 TB (1 TB WDC Black + 4 TB WDC Green)
Power Supply: Corsair TX750
Cooling: Corsair H100
Case: CM HAF 932
Display: Dual Monitors (Benq G2420HD + Dell SP2208 WFP)
Keyboard/Mice: Razer Blackwidow Ultimate + Razer Mamba
Laptop:
Alienware M15x
krish_puri is offline
Old 04-12-2008, 12:10 PM   #2 (permalink)
Point Blanc
Default Re: Buying a new MOTHERBOARD and PROCESSOR upto 25k??
C2Q + mobo from Asus P5Q Series pr MSI Platinum/Diamond + DDR2/DDR3 RAM
have you checked prices locally.
acewin is offline
Old 05-12-2008, 08:21 PM   #3 (permalink)
KrishPuri.com
No,
I didn't know what to buy so I haven't checked any prices...
Case: CM HAF 932
Laptop:
Alienware M15x
Old 05-12-2008, 08:44 PM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
Originally Posted by krish_puri View Post
Hi Guys,
Cheers
Krish
Great Budget dont worry u can get Superb proc and motherboard for 30K
the Only CORE2QUAD processor which is just near to Corei7 and sometime it equals the performance of Corei7
The processor is
CORE2QUAD Q9550[12MB L2 Cache + 1333 FSB + 45nm] ======> 16600/-
The Motherboard Stable & Good for better OCing means
MSI ZILENT (which comes with zalman cooler)[p45 chipset + 1600FSB + free zalman cooler] ===> 11300/-
if u take the X48 chipset means the stable mobo means it cost around 20k+
the another good and expensive option is ASUS RAMPAGE EXTREME ====>27k
MSI (platinum or zilent) mobo is brilliant and good for gamers /----- go for it
16600+11300======>27900/-
cool , but one thing 8600GT ???
damngoodman999 is offline
Old 06-12-2008, 07:28 AM   #5 (permalink)
toofan's Avatar
Processor: Intel Core 2Q 9550 (2.83 GHz) : Rs. 17000.00 (street price may be low.)
Motherboard : ASUS P5Q-E : Rs. 10000.00
and If you are looking for a good gaming machine then try to Buy at least a Palit's HD 4850 for around 9k.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 06-12-2008, 07:47 AM   #6 (permalink)
Point Blanc
did not knew that a stable X48 would cost much
price of MSI X48 Platinum is around 13-14K
also 8600GT old but not bad, if he has then he should use it. Its upto him how to keep his sytem, why spend unneccesarily. He can buy a separate GPU anytime, current prices have also to be noted, they rose alot just because of dollar price rising.
@krish you did not mention if you are including RAM in this budget or not.
So, I will try putting things in total perspective plan it as your wish.
Intel C2Q 9450 in less than 15K rides over C2Q 9550, the difference is not that much to spend 2K more.
Mobo, MSI P45 Platinum/Zilent 10-11K has Zalman Cooler in it
Asus P5Q Pro in 8.8K
Biostar TP45 in around 6-7K
The above have DDR2 RAM base
MSI X48 Platinum in 13.5-14K
Asus P5Q3 Deluxe WiFi (P45 chipset mobo)15K
Asus P5Q3
MSI P45 Diamond with combo of DDR2 and DDR3 with crossfire
Asus P5QC combo DDR2 and DDR3 but no crossfire
alot many recommendations and 15K is max for best of P45
My recco is Asus P5Q Pro or MSI P45 Zilient and Biostar TP45which ahve DDR2 base
DDR3 prices is very high almost 4 times of DDR2,
You will have to check for combos if wanna have DDR3 latter
and if want to have DDR3 RAMs I gave the mobos.
That is why I asked you to check few pricing. atleast for DDR2 and DDR3 RAMs in the market.
and later reco will be buy a gfx card latter on for sure. Prices have decreased alot, so have something good. you can even keep 8600GT if you do not think much of gaming. Though I am sure you will change gfx card in next 5-6 months for sure
acewin is offline
Old 12-12-2008, 11:23 PM   #7 (permalink)
damnbadman666
Originally Posted by wangprefix View Post
hey guys can you give the exact price as on 12/12/08 of the mobos msi p35 diamond and the msi p45 diamond would apreciate it greatly. help me out here guys
Dont know about P35 cause its very worst chipset , but MSI P45 diamond is great cost 10.2K
Old 13-12-2008, 08:25 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
seriously, if you need high perf components,
1) Intel Core i7 920: 15k
2) Gigabyte X58 GA-EX58-DS4: 13k-14k.
3) Corsair 2x1Gb DDR3 1333MHz RAM: 6k-7k
Yes it overshoots your budget by 5k. But this rig kills most of core 2 extreme processos without mercy
Note: MSI X58 board is having serious BIOS issues (mobo dies). Get ASUS or Gigabyte models
desiibond is offline
Old 13-12-2008, 11:05 AM   #9 (permalink)
The Sorcerer's Avatar
But why are you wasting so much for a mobo- processor when you have an 8600gt. Its makes more sense to buy a cheap board+ processsor with a decent graphic card. You need to set your upgrade priorities straight.
Hardware BBQ
The Sorcerer is online now
Old 20-12-2008, 12:08 AM   #10 (permalink)
KrishPuri.com
I am also looking for a very good graphics card. Budget is not a problem for me. So I can go with the top ones that will be good with my motherboard.
Also, I think I will go with DDR3 in RAM.
And because I reside in Delhi, can you please tell me the latest prices in Nehru Place (if possible).
Case: CM HAF 932
Laptop:
Alienware M15x
Old 21-12-2008, 08:42 AM   #11 (permalink)
toofan's Avatar
If you are thinking of buying ddr3 ram then you must go for Desibond's config.
and for a good gfx card like HD 4850 you will hv to spent 9.5k more.
Check my work at:
toofan is offline
Old 21-12-2008, 10:54 AM   #12 (permalink)
Intel OCer
amitash's Avatar
+1...destroys all 50k core 2 extreme processors by quite some margin...To this add a palit HD4850 at 10k or an HD4870 at 16.7k if your budget allows and you will have a monster config....see my core i7 review if you want to see the performance of core i7 against core 2 extreme.
My site: collegeclassroom.org
amitash is offline
Old 21-12-2008, 12:14 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Wait for Nvidia GTX295, the new king!!!
Should be around 30k
Old 21-12-2008, 01:48 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
But if u wait for GTX295,u can certainly wait till HD4850x2's 299$ price hits India.
Then u can get it for 16.5k, how's that a deal?
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 21-12-2008, 02:32 PM   #15 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Buy a 790FX motherboard with SB750 chipset and 4-way crossfire capability for 10K and get a sempron LE 2.1GHz CPU for 1.4K.
On january, you can buy an AMD Phenom II 940 quadcore 3.0GHz CPU for 15K.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 21-12-2008, 02:40 PM   #16 (permalink)
Intel OCer
amitash's Avatar
^he said budget not a big prob...you can get the forementioned cre i7 only config for 34k no...also he wants ddr3
amitash is offline
Old 21-12-2008, 08:26 PM   #17 (permalink)
jck
+1
jck is offline
Old 21-12-2008, 08:49 PM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Don't worry mate. He is going to get a GPU too
Old 22-12-2008, 05:16 AM   #19 (permalink)
KrishPuri.com
Yeah, that is exactly what I am saying. I am actually looking for a monster configuration and I do not have any budget problems.
For the GPU, how about the nVidia GeForce 9800 GX2?? How does it perform and what is its price?? How powerful is the GeForce GTX 295 and when is it releasing?? I can wait for it...
I can do with DesiBond's configuration and till the release of GTX 295, I can use my current graphics card...How about this?? Will this configuration be good enough??
Case: CM HAF 932
Laptop:
Alienware M15x
Old 22-12-2008, 07:29 AM   #20 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. wait for the release of GTX295. It is now the fastest card on earth, beating HD4870 X2 with slight margin. You can also check HD4870X2 and HD4850X2 if you think GTX295 if too costly.
Or waiting for the price of GTX295 is a better choice as you will also see a flurry of price cuts by AMD and nVidia to give way to GTX295.
Old 22-12-2008, 08:39 AM   #21 (permalink)
Intel OCer
amitash's Avatar
gtx295 is not likely to be cheap by any margin...im pretty sure its going to be over 35k here in india...you can get the 4870x2 for 25k though and dont get 9800gx2..its easily beat by a 4870....thrashed by a 4870x2
amitash is offline
Old 22-12-2008, 02:53 PM   #22 (permalink)
KrishPuri.com
Has 4870x2 released in India?? If not, when is the the expected release??
Is it actually releasing in India for that price?? If so, when??
Case: CM HAF 932
Laptop:
Alienware M15x
Old 22-12-2008, 05:02 PM   #23 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
The price wud be as much or a bit higher than HD4870X2 during it's launch, and it's not a margin, it beats HD4870x2 by as much as 20frames in some games.
About me:
Old 22-12-2008, 07:14 PM   #24 (permalink)
The Smaller Bang
WHERE can you buy a 4870X2 for 25K in India ?
Old 22-12-2008, 07:35 PM   #25 (permalink)
SA ~San Andreas
Does anybody know a good PCIX16 graphics card for 2000-4000?
sa_still_rocks is offline
Old 22-12-2008, 08:06 PM   #26 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
GF 9500GT^^^
Has ur clock turned bak, it's there for months now
About me:
Old 22-12-2008, 08:22 PM   #27 (permalink)
Get Nvidia 8600 with 256DDR3 for < 4K.
V.Prem Kumar
janitha is offline
Old 28-12-2008, 12:54 PM   #28 (permalink)
KrishPuri.com
Just bought the following configuration:
Intel Core i7 920
Intel Desktop Board DX58SO Extreme Series
Transcend 4GB (2 X 2 GB) DDR3 1333 MHZ
Can you tell me when is the GTX 295 releasing in India??
Case: CM HAF 932
Laptop:
Alienware M15x
Old 28-12-2008, 02:45 PM   #29 (permalink)
Intel OCer
amitash's Avatar
^nice choice on the procy..hoq much did you pay for the mobo?? i would have gone fr gigabyte UD5 for 16.5k but the intel one is pretty decent too...And how much did you pay for the RAM? the i7 has a tripple channel controller you would have gotten better performance with 3 1GB sticks instead of 2 2GB sticks...still its a great config congrats!!...with a GTX-295 it will be Uber fast.
amitash is offline
Old 29-12-2008, 10:54 AM   #30 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Intel Core i7 920
Nice choice. Congratulations
am not sure about the GTX295 release date in India
Buying a new MOTHERBOARD and PROCESSOR upto 25k?? krish_puri Hardware Q&A 9 29-07-2008 08:52 AM
motherboard upto 5k ayush002 Hardware Q&A 6 18-06-2008 03:45 PM
buying new mobile budget upto 12000/- niks999 Buying Advice 13 22-08-2006 11:37 AM
Help needed for buying motherboard, Processor and RAM montylee Hardware Q&A 6 07-11-2005 09:27 AM
Regarding buying AMD 64 bit processor guhanath CPU / Motherboards 8 02-04-2005 09:48 PM
