Re: Problem in connecting my Portable Hard Drive to my PC. Need Help
Ok, let tell u a story, c if it matches ur condition.
My friend bought one 80GB portable maxtor HDD. Its fully USB like urs. It has two USB ends comparing to normal One USB which goes to PC and another End(don't know wat it calls) which goes to ur HDD.
Initially when we connected only one USB end to Lappy, the drive was not showing, we tried several times, but same thing. Then we tried with inserting both the USB cables in Lappy and it worked.
Now this will come handy if ur drive has also same USB connector and u can try as we did.
Else, check ur USB ports, they might not getting proper power.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
