Old 30-11-2008, 06:30 PM   #1 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default DDR1 and DDR2
I have a small doubt regarding the RAM
Is there any performance difference between DDR1 400Mhz and DDR2 800MHz
specially in games...?
Suppose a new game require 2gb ram. do they mean 2gb DDR2..?
Or 2gb ddr1 will meet the same performance in that game...?
ajai5777 is offline
Old 01-12-2008, 10:58 AM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: DDR1 and DDR2
While at the same speed(frequency), both DDR and DDR2 transfer the data at the same rate.
i.e the data transfer rate of DDR400 and DDR2-400 is same(3200 MBps). But DDR has the upper limit of 400MHz, which is the lower limit of DDR2- the upper limit being 1066MHz.
In case of gaming and other apps a faster memory means that the data can be transferred faster from RAM to the other components.
Like in the case of DDR2 800 MHz, the data transfer rate is 6400MBps, double of the DDR2/DDR 400MHz(3200 MBps).
A faster memory helps in faster starting/loading/reloading/exiting times in case of games.
cynosure is offline
Old 01-12-2008, 12:03 PM   #3 (permalink)
toofan's Avatar
+1 for the above post and one more thing. Price difference. DDR2 is quite cheap now, even cheaper then DDR1.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 01-12-2008, 04:43 PM   #4 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Ram speed has no critical role in game play?
Only help in faster loading starting etc?
Main thing is the quantity?
ajai5777 is offline
Old 03-12-2008, 01:42 PM   #5 (permalink)
UbuntuUser
cynosure's Avatar
^In a way yes. Because the level that you are currently playing is loaded onto the system ram and its upto the cpu/gpu to process the data and display it onto the screen.
Moreover, if your motherboard supports DDR then it wont support ddr2, so the only option is to increase the ram as you cannot use ddr2.
Most of the processing in games is done by the graphics card which has its own ram- faster than the ram used on motherboard. If your gfx card is outdated then even your system ram wont help.
cynosure is offline
DDR1 or DDR2 ? champ_rock Hardware Q&A 3 26-06-2008 09:49 PM
Asus K8VMX Mother board DDR1/DDR2 midhu Hardware Q&A 2 02-05-2008 07:30 PM
will ddr2 work in ddr1???? Omsck Hardware Q&A 6 09-04-2008 12:47 PM
S 1GB DDR2 @667MHz COMPATIBLE WITH 2GB DDR2 @800MHz amrawtanshx QnA (read only) 1 10-03-2008 08:57 PM
