Old 30-11-2008, 12:28 PM   #1 (permalink)
New Gen Guru
sujoyp's Avatar
Red face sata2 on intel865 MB
HI friends, can I connect SATA2 harddisk on Intel865gvhz motherboard....it contains SATA port...
Does SATA2 fits in SATA1 port.....is it good or should I go for IDE hard disk
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now
Old 30-11-2008, 12:55 PM   #2 (permalink)
Cool G5's Avatar
Default Re: sata2 on intel865 MB
You can connect SATA 2 HDD to SATA 1 port.
The cables are same, but remember SATA 2 HDD will throttle down to SATA 1 speed, if the motherboard dosn't support SATA 2.
Cool G5 is offline
Old 30-11-2008, 05:24 PM   #3 (permalink)
New Gen Guru
sujoyp's Avatar
thanks for the reply
but is SATA1 speed is still more than IDE 7200rpm ???
Photography Gears -
Old 30-11-2008, 07:48 PM   #4 (permalink)
Alive Again...
satyamy's Avatar
YES it is
Speed
SATA I = 150mb/s
SATA II = 300mb/s
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 30-11-2008, 08:52 PM   #5 (permalink)
New Gen Guru
sujoyp's Avatar
Originally Posted by satyamy View Post
YES it is
Speed
SATA I = 150mb/s
SATA II = 300mb/s
great...thanks man
Photography Gears -
SATA2 with SATA1 Kenshin QnA (read only) 5 12-01-2008 05:01 PM
HDD Casing for an SATA2 HDD abhinav_bipnesh Hardware Q&A 21 12-09-2007 05:28 PM
suggest me sata2 hdd for RAID 0 ranjan2001 Hardware Q&A 1 15-04-2007 01:02 PM
ASRock 939Dual-Sata2 vinodh.p QnA (read only) 1 12-09-2005 03:10 PM
